Need some help after a timing belt change!
Just got back from the mechanic who did my timing belt. After everything was put back together, the car runs very rough.
Thing is, when I first test drove it - the battery was dead and it took about 10 minutes of starting and stalling and a bad idle and then all of a sudden, it ran great. I figured the brain needed to "re-set" itself after the battery was unhooked.
The battery was unhooked again for the belt (and other stuff). The mechanic took off the air intake hoses and I remined him it was a hotwire system and he put the hoses back on and it idled great - but if you give it gas....nothing.
He took the hoses off again and put his hand over the air intake screen and it ran perfect - took the gas and everything. He thinks it's the air sensor, but I still think it just needs to re-set itself.
What do you all think? That sensor is costly and I don't want to get it put on if it's not needed. Anyway to check it or is there a procedure upon re-starting the car after the battery was unhooked?
Thanks,
Jeff
Thanks,
Jeff
I guess a MAF (air flow ) could die at any time, but I'd start by going back over all the things touched/disturbed/opened during the TB procedure.
There are the usual sensor connectors, as on top of the thermostat housing. Perhaps the more critical is the 14 Pin connector of the front engine harness as it engages it's male socket just behind the hot terminal on the right fender ( this was opened in the procedure).
The LH & MAF Guru's frequently recommend disconnecting the MAF harness and restarting the car: if it runs better in a 'limp home mode', the MAF is suspect. From the "test drive" experience, the MAF connector may also need to be cleaned up. ie., you're seeing the same (intermittant) experience again.
Received 1,692 Likes
Re: Need some help after a timing belt change!
Garth's idea of checking all the stuff that was disturbed by your (ex-)mechanic is a good one. Go to Pirtle's site:
http://members.rennlist.com/pirtle/
and use his excellent timing belt change procedure as a guide to what you need to check.
