Bose subwoofer adapted for the 928
Thanks Michael, a pic would be great when you have time.
Shawn, could love to see this option and how well it fits. Cost wise I can get that amp here ~NZD450, which is better value than buying 2 of the 445u. The spec I can see online claims 1 3/4 inches high so I was worried about height fit. Also, it from the spec is seems if you want you main speakers at 4 ohms you can't have the sub a 2 ohms. Mine is the 2 ohm sub, maybe yours is a different model?
- 80 watts RMS x 4 at at 2 ohms + 350 watts RMS x 1 at 2 ohms
Here is the installation of the Alpine amps. Both of these fit under the stock cover. You can see the aluminum bar stock used (from home depot) to mount the amps to and mount to the factory holes in the chassis.
The following 4 users liked this post by Michael Benno:
Dang, that is really tidy. I might have to follow your lead on this (also) to clean up what's in my car right now. As you know, there are some issues that need to be addressed anyway.
Cheers
Cheers
Michael Benno (09-20-2022)
The Bose woofer from a Nissan Rogue also fits in an S4 spare, and has a built-in mono amplifier. Part JM20A.
The amp (part 297171-003P) is 70W into 1ohm load and works with the 1-ohm rated woofer.
The easiest option is to buy one of the subs with the wiring cut off, so you have both sides of the harness at the connector, to wire into. If you look at the connector from the harness side (clip facing up as shown), the pin numbers are marked as follows:
2 | 4 | 6
1 | 3 | 5
1 = Brn = Audio signal - (line level)
2 = Yel = Audio Signal + (line level)
3 = Braided (thin black) = Shield for audio signal
4 = thin Grn = Amp ON Signal (12V switched)
5 = thick Black = Ground
6 = Thick grey (some reported black with silver stripe? mine is bluey-grey) = Battery +12V (fuse here)
The amp side of the harness has different colours (of course) - using the same numbering above..
1 = yellow, 2 = purple,3 = white, 4 = blue, 5 = black, 6 = orange
Lastly, in case you're tempted to experiment with other models.. I also previously bought a late Murano Sub, 1BM0A, which has two woofers and an amp built in, but it does not fit into the S4 spare wheel.
2 | 4 | 6
1 | 3 | 5
Oh - also thank you George ( @19psi ) for the info on using a Bose subwoofer.. it was his original post on the Bird site in 2013 which led me on the journey: http://forums.pelicanparts.com/porsc...tock-look.html
19psi (09-20-2022)
I was looking into a drop-in solution but already had an amp I wanted to use and I was in the mood for a woodwork project. Using every inch of the space in the spare wheel area and 13mm thick MDF was enough air volume for a 10” sub. Used it for the first time just now and a massive improvement over the speakers I’ve been trying in the B pillar.
Once the protecting grill arrives I’ll put the cover and carpet back over it.
2 | 4 | 6
1 | 3 | 5
2 | 4 | 6
1 | 3 | 5
this is a really great option and allows for a lot more flexibility to choose a 6-channel amp for the cabin 10-speaker system in 90+ cars or a 4 channel amp in the 8 speaker system in early cars
Tried copying Michael Benno idea and I'm having some trouble. The first problem is that it isn't very loud. I wired it up to both left and right speakers in the rear trunk area and I can barely hear the subwoofer. It does work, but not very loudly. It might as well not even be there.
powering all the speakers in the car, mainly because it's small and fits the stock location. The stereo still sounds loud, just not the subwoofer. Not sure if I need to put an AMP just for the sub or maybe my wiring wasn't done correctly. I didn't take the time to figure out which set of wires go to left or right, assuming the set of wires are associated with left and right. I also didn't take the time to pay attention to which wire is hot and ground. There's also the mounting of the subwoofer which as you can see is off center. Not sure if I need some adapter to get it to bolt center? I have a 1985 Porsche 928.
Tried copying Michael Benno idea and I'm having some trouble. The first problem is that it isn't very loud. I wired it up to both left and right speakers in the rear trunk area and I can barely hear the subwoofer. It does work, but not very loudly. It might as well not even be there. I do have a cheap Boss 200 watt AMP powering all the speakers in the car, mainly because it's small and fits the stock location. The stereo still sounds loud, just not the subwoofer. Not sure if I need to put an AMP just for the sub or maybe my wiring wasn't done correctly. I didn't take the time to figure out which set of wires go to left or right, assuming the set of wires are associated with left and right. I also didn't take the time to pay attention to which wire is hot and ground. There's also the mounting of the subwoofer which as you can see is off center. Not sure if I need some adapter to get it to bolt center? I have a 1985 Porsche 928.
The first issue that I see is that you are trying to power the sub-woofer off of the 2-channel amp you have. Subwoofers operate on separate frequencies and require a dedicated channel where you can isolate the frequencies being sent to it in order for it to work correctly.
The second issue is that the impedance of that subwoofer is 2-Ohms and the rest of the OEM speakers in your 1985 model year car are 4-Ohm. Unless you changed the factory speakers to 2 Ohm, you cannot have different impedance level speakers driven from the same channel.
You will need to find a power source to drive the sub. The sub will require about 45-90 watts to drive it properly. Also, you need to limit the frequencies being sent to the sub to between 20–200 Hz. Most Mono amps have both of these capabilities. Some multichannel amps have subwoofer outputs as well. You just need to make sure the amp supports 2ohms. If your head unit has a dedicated subwoofer output then it can send the frequencies to any amp as well.
Some additional questions:
1. What is the head unit in this car?
2. Are you running the 8 original OEM speakers or aftermarket speakers? If the latter please provide the impedance and number of drivers and locations.
3. can you confirm if this sub woofer is not the powered version, meaning there is no amp inside (remove the cover). If you have the powered version then you need less stuff.
Hi, not a reply to dukenukemx question, rather a new one. I've been trying to find a good 5 channel amp for this that fits in the original space, loved the Picasso that Shaun suggested but it's just a little big. Reading Michael's reply above, realised that my SQR46 has a sub out. So if I'm happy with the volume for my front and rear speakers powered directly from the head unit (which I am), am I correct in thinking I can just place a mono 2 ohm amp in the orginal amp location to power the sub? I have the unpowered Bose from a wrecked Nissan. Feeling like I should have clocked on this before, so asking just in case I have been around this path and forgotten something!
So I need a mono amp that puts out at least 45-90 watts and works between 20-200 Hz. Would wiring it entirely to the left side temporarily make it louder?
dukenukemx (07-05-2023)
Hi, not a reply to dukenukemx question, rather a new one. I've been trying to find a good 5 channel amp for this that fits in the original space, I loved the Picasso that Shaun suggested but it's just a little big. Reading Michael's reply above, realised that my SQR46 has a sub out. So if I'm happy with the volume for my front and rear speakers powered directly from the head unit (which I am), am I correct in thinking I can just place a mono 2 ohm amp in the orginal amp location to power the sub? I have the unpowered Bose from a wrecked Nissan. Feeling like I should have clocked on this before, so asking just in case I have been around this path and forgotten something!
BTW, I have not found a 5 or more channel amp that will fit in the factory location. This little guy came on the market recently and I wonder if it would suit your needs:
Clarion XC2510 Compact 5-channel amplifier — 50 watts RMS x 4 at 4 ohms + 300 watts RMS x 1 at 2 ohms
I am extremely happy with the dual Alpine Amps I have in my car and I see that there have been some updates to the amps. Using 2 may be a good solution. I found the factory speaker sound very good with a good amp driving them (assuming the speakers are in good condition).
@dukenukemx
You absolutely cannot share that 2-channel amp between a sub and the other speakers. The frequencies are different. The sub requires very low frequencies. The door speakers and B-pillar speakers use high and mid frequencies. If you send those high/mid frequencies to the sub, you will get very low outputs (as you are hearing) and will not get any deep base. Amplifier stereo channels are paired left and right, they are not meant to be divided among unpaired speakers. You would loose "Stereo" if you do. When driving a sub from an amp shared with other speakers, you need a dedicated mono channel or a dedicated pair of channels (L&R).
Let's get back to the outputs on the head unit. Which Xtrons model do you have? can you provide a link? I can look it up and let you know if you can drive your sub from that.
Regarding the speakers, we still need some specifications on the impedance. Can you provide links to the speakers that you have installed? That way I can look them up and provide guidance.
One potential solution direction is that you power your speakers directly from the head unit and power your sub from the Boss 2-channel amp. In this scenario the left and right outputs on the amp would each power a voice coil in the sub. See the dual voice coil diagram below.
