928s 1986. Could any experts out there identify this piece. Found it between radiator and oil cooler(I think that’s it). It was lose down between the two of them. Would love to repatriate it to its correct location. May have dropped off from something while I was replacing brittle oil vent and vacuum lines. Had air intakes off numerous times. Plastic piece Location where I found it
I think it's a plastic shield that protects the front body harness from chafing as it runs across the backside of the upper radiator support. Here's a pic of that piece installed on an early '78.
that sounds correct thank you, I replaced the front harness 3 wks ago. And that was a mammoth task. Thanks all
