Is the behaviour normal then? Air being sucked in at idle? Or is the valve faulty and leaking?
Cheers
John,
If there is a whistle then you have a leak and it needs to be addressed. It may not be serious or need immediate attention but it is not likely to get better by itself.
Are you sure the leak is on the flappy spindle? If so i doubt the problem can be solved with the manifold in-situ. You could squirt something like WD40 at the site to see if the whisling stops whilst the fluid flows
Irrespective, chances are whatever is causing the leak can only be resolved with an inlet manifold off job.
based on your report the shaft bearings need to be replaced,
Roger has new double sided O ringed bearings you need 4 of them.
2 for the flappy shaft
and 2 for the throttle shaft.
NOTE the originals are single side O ringed bearings
