Coolant spray front of engine
Drove 5 or 6 miles to the auto parts store to get more coolant and test the system. Light was not on - not sure if because I cleaned the plug or filled the tank. Came out of store and a little puddle of coolant behind the front passenger tire - fully expected an overflow, as I put a little extra in. For giggles, opened the hood to check it - the coolant was at the full mark, but coolant spray is all over the front of the engine
Sprayed everywhere. Decided to drive home and listen carefully and watch things. No strange sounds whatsoever. None! Car temp never went above the normal mark for it - just above the low white line. Oil pressure fine, no unusual readings there. Drove home with no issue.I got home and pulled the cross member and the air tubes and air box to get a good look at everything.. Took some pictures too. What could it be? No spray back by the overflow tank at all. It's all up front, by the water bridge, on the timing belt covers, belly pan and some in the vee. It looks like one of three things - o-ring failure? Water pump failure? Or worst case - head gasket failure?
Note - I did a full top end refresh last year in the spring - new o-rings, water pump, everything. Clean enough to eat off of too. Now covered in white crusty coolant. Looking for the wisdom of the board. Thanks!
I like the interesting leaks..
I vote for inner hose failure, coming out the end at the threads. That one was haunting me for a while before I got a pump. Flew around everywhere.
That was a fun one to locate.
I had to pressurize it from a regulated air source, because the game pump wasn't keeping up with the leak.
Please can anyone post a pic of the adapter they have which fits, and/or any dimensions?
Thanks a lot
Thanks a lot
Thanks a lot
Well, there you go:
The hose has a tear on the top. There appears to be sufficient slack to trim off an inch or two, and reattach it without getting a new hose. I will pressure test once I make the repair to ensure no other compromise to the cooling system, but I do think this is all it is. And of course, a big friggn mess to clean up from what was a very clean engine.
