928 Forum 1978-1995
Sponsored by: 928 Specialists
A newbie with a few questions
Old 06-16-2021, 07:27 PM
bwsjr
8th Gear
bwsjr's Avatar
Default A newbie with a few questions
Yesterday, I took delivery of a 928 S4 with 95,000 miles. I have never owned a 928 before.
After looking it over and driving it about 20 miles home, I have some questions for those of you more familiar with this beast.
1. What replacement tires do you recommend?
2. What questions should I be sure to ask an experienced Porsche mechanic I hire?
Tires:
  • Currently fitted with Sumitomo HR+ M+S
    • Front — 225/50ZR16 92W date code 2502
    • Rear — 245/50ZR16 97W date code 0304
  • All tires have excellent tread
  • All tires vibrate a lot as though flat spotted
  • Tires are 19 years old in the front and 17 in the rear
  • My priorities for new tires are:
  1. Quiet ride
  2. Soft GT ride
  3. Handling
  4. Safety at higher speeds
  • If I drive it in winter, I will buy winter tires
Mechanic:
  • I have experience working on other cars, but I'm naive re: a 928
  • I have found at least two reputable options in town
  • I understand that if they are worth their fee, they will know what to address
  • I’m looking for things that they might assume I know or that have been cared for already (I’m still looking through the extensive service records)
Thanks for any help you can offer.
Bud
Last edited by dr bob; 06-18-2021 at 04:36 PM. Reason: cleaned formatting description text
Old 06-16-2021, 07:42 PM
Alan
Electron Wrangler
Alan's Avatar
1) Tires - I don't know because my priorities are different than yours - but you will find lots of advice. Change them before you drive far - they are Way Old.
2) Make sure a potential mechanic actually knows something about 928s or you will pay him a lot for him to learn - while he makes mistakes on your car (don't do that)
Mechanics at the dealer will mostly be like this too! (the 928 may have stopped production before they were born).
We need to know if its an Auto? I assume so?
Alan
Old 06-17-2021, 10:10 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,315 Likes on 1,289 Posts
Nice car,
so where do you live? that will assist in finding a local mechanic,
NOTE If you have an auto make sure to get a flex plate check done,
that includes retorquing front and rear pinch bolts and checking the crank end play.
Old 06-17-2021, 10:12 AM
bwsjr
8th Gear
bwsjr's Avatar
Yes, it has an auto, which, for this car, I wanted.
Sorry about the code appearing on post. I do not see a way to edit it out now.
Old 06-17-2021, 10:13 AM
bwsjr
8th Gear
bwsjr's Avatar
Omaha, NE
I will greatly appreciate the help!
Old 06-17-2021, 11:25 AM
FredR
FredR's Avatar
If the rubber is that old chances are the service history has probably fared no better.
Stan has covered the flexplate check already- look up "TBF" in the 928 forum search engine. I would also suspect the timing belt has fared no better if the tyres are that old unless you know for sure it was changed out much more recently. Whilst dealing with the timing belt you need to check the cam shaft and oil pump sprockets for wear.
Besides the normal service items a coolant change may well be long overdue, same for ATF and diff oil. If you have no confidence in the service history just change out all fluids and the spark plugs.
Old 06-17-2021, 01:45 PM
Michael Benno
Michael Benno's Avatar
If you can, see if you can identify a tech with specific experience with 928s. You will likely be able to find a good quality technician to work on a 928. They will likely be able to get access to parts diagrams and workshop manuals and figure out how to do the repairs. However, there are a lot of very specific repair techniques on a 928 and there are several common adaptations to repairs that are usually only known by folks with specific experience. So you may find some of these repairs being sub optimal, or worse, needing to be redone. Additionally, some of the troubleshooting, particularly with electrical systems, can be time intensive even for those who have that specific experience. These troubleshooting adventures can become quite costly for you. I have had several repairs that were done incorrectly (by the Porsche dealer) that ended up causing problems later on.
My recommendation is that you commit to learning to work on your 928. The build quality if fabulous and they really are a joy to work on. You sound like you have the raw skills to do the work, you just need the specific knowledge and that is where this forum comes in. Just about every problem and repair procedure is already documented. You can search it up and reply to old threads, or feel free to start a new thread because we all like to talk about the repairs and we could use some new content ;-). You will also need to find a good 928 tech to help you with work well outside of your skills as well. But being able to regular maintenance will be extremely useful.
Here is a link to my google drive where I have posted a wealth of documents, factory manuals, repair procedures, and tips. This information was given to me by fellow list member Wanye Strut and I have continued to add to it.
This has been my journey with the 928's, I am a newbe mechanic and the forum has been super useful in encouraging me to take on projects I feared were far too complex.
You got this!
PS, dont forget to post picks of your car, we LOVE pictures.
The following 3 users liked this post by Michael Benno:
928NOOBIE (06-17-2021), Bertrand Daoust (06-18-2021), dimi5928 (06-18-2021)
Old 06-18-2021, 04:15 AM
Darklands
Darklands's Avatar
Received 1,131 Likes on 606 Posts
The rear tire size should be 245/45 R 16.
This tire size is really rare. If you like to drive an premium tire on the 928 and you should I recommend Pirelli or Michelin.
245 45 r16 günstig kaufen mit Preis.de
This is the range you can buy in germany. 17 " rims have way more choices.
Old 06-18-2021, 10:11 AM
bwsjr
8th Gear
bwsjr's Avatar
I didn’t realize Dunkin’ Donuts sold tires!
Old 06-18-2021, 10:53 AM
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,233 Likes on 476 Posts
Michael,
Just took a look at you Google Drive link.
Wow!
Thanks so much for posting the link of this great document.
Tons of information there!
Old 06-18-2021, 12:45 PM
bwsjr
8th Gear
bwsjr's Avatar
Tire Rack likes the Goodyear Assurance ComfortDrive as an all-season Grand Touring tire. The reviews also seem to bear out their quietness and comfort. Of course, they are only available in 17" size, so I'd need new wheels.
Old 06-18-2021, 03:47 PM
fiatrn
fiatrn's Avatar
Can't he use 225s front And rear?
Old 06-18-2021, 04:43 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
The S4 cars came with staggered 16" wheel widths, so the wider rear tire is appropriate. The original 245/45-16 rear size was shared with period 911 turbo cars, so there's still some market to get them made. But batches tend to be smaller and gaps in availability are pretty common. Tire Rack reps used to keep waiting lists for them, and would call to let folks know when stock was available.
Old 06-18-2021, 05:00 PM
Darklands
Darklands's Avatar
Porsche has a small batch of N approved tires for the cars, the Pirelli and the Michelin.
Old 06-22-2021, 11:32 AM
bwsjr
8th Gear
bwsjr's Avatar
Default 928 16" tires
These appear to be the tires offered by Porsche dealers for fitment to the S4 with 16" wheels. These tires were developed in the late 1990s and are sold without any warranty. I have not yet found any reviews about them - particularly about noise and ride. Does anyone here have experience with these? They seem like the ONLY option for installing a 245/45 R16
Available from Porsche dealer and Tire Rack.
Quick Reply: A newbie with a few questions
