928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing marks 180 degrees out
Old May 29, 2021 | 06:09 PM
matwelli's Avatar
matwelli
Default Timing marks 180 degrees out
Any guess to whats going on here, just about to replace the timing belt... Car runs, guessing somehow the orange plastic band with the timing marks has been taken off and put back on? Also check the third photo, shows the band is also been put on backwards ( note where 45 deg is)
Painted mark at 45 deg btdc, by previous belt change
And this is the crank pulley at 45 deg btdc
This third photo i have rotated the crank to get to the markings.... Notice anything?
Old May 29, 2021 | 06:16 PM
FredR's Avatar
FredR
The damper is on back to front- look at the markings- they are upside down
Old May 29, 2021 | 06:18 PM
Wisconsin Joe's Avatar
Wisconsin Joe
The harmonic balancer was put on backwards.
No big deal. Make sure you put it on correctly when you put everything back together.
Edit to add: Dog gone it. Fred beat me to it....
By two minutes.
Old May 29, 2021 | 06:22 PM
FredR's Avatar
FredR
By two minutes.
Team work!
Old May 29, 2021 | 06:33 PM
matwelli's Avatar
matwelli
Default Have a good hard look at photo 2
Does not explain photo two however gents.
Old May 29, 2021 | 06:40 PM
FredR's Avatar
FredR
I take it you understand the balancer is keyed
Old May 29, 2021 | 06:44 PM
matwelli's Avatar
matwelli
Sure do, photo two, the timing marks on the balancer are 180 degrees out from tdc.... They are on the bottom of the pulley in that shot. With the balancer keyed there is no way that could happen. So interested to see what has been done here. Will install the flywheel lock later today and take it off
Old May 29, 2021 | 07:03 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
OK lets start over
when whomever put that crank damper back on they installed it back wards.
NOTE since the cams were already lined up it didnt matter that the damper went on backwards as the engine was properly timed.
That said put the engine at TDC with the cams lined up .
You could also remove the #1 plug, put a piece of hanger wire in through the plug hole and rest it on the piston and verify that the piston is at TDC.
NOTE #1 is first plug on the passenger side.
Remove the crank bolt after installing the flywheel lock.
turn the damper over so you can read the number as you face the engine.
That said if the crank damper wont line up then the damper may have separated from the hub and turned
NOTE the crank will be at TDC when the woodruff keyway is pointing at the 4 O clock position
Old May 29, 2021 | 07:32 PM
matwelli's Avatar
matwelli
All good, i am an idiot, was only the balancer on backwards... In my head i saw two seperate things happening. Need more coffee
Old May 29, 2021 | 07:37 PM
Billu's Avatar
Billu
The reason the answer came quickly is that many of us have done the same thing.
You are not an idiot for doing this.
