Water Pump Failure Thread
#46
I agree 100%.
One more block that looks like this is way too many.
I'm really sick of seeing/fixing this damage.
I removed a GEBA pump yesterday. The bearing feels perfect and the pump seal doen't even weep.
And it's probably has the best bearing I've ever spun...absolutely butter smooth!
Do I put it right back on, fully knowing that somewhere down the road, this pump will fail...and the result will, most likely, resemble this picture?
It's become really difficult for me to use a pump with a metal impeller and fall asleep that night...
Why can't GEBA, apparently a large water pump entity, use a plastic impeller?
With their casting, their bearing cartridge, and their seal, that might be the perfect alternative.
"We know the pumps are for the 928 and we've heard of these problems too.
We have not yet had the problem with our pumps, as the impellers are pressed onto the shaft with great force and can no longer change their position.
In addition, our dimensions are always approx. 0.2-0.3 mm below the original dimensions.
We can imagine that this problem is caused by a worn out bearing shaft!
There is then a movement in both the axial and the radial direction, which, given the small gap dimensions, then leads directly to contact with the engine block.
But of course these are only assumptions, as we have not yet seen a pump where the impeller grinded on the engine block."
#47
The Parts Whisperer
I asked one of my suppliers today "Do you seen any difference with warranty returns between Geba and Laso"
his response was "Not really. Geba & Laso have always been about the same"
#49
I finally got Rick's car buttoned up and the AC blowing very cold and then today the water pump gave it up.
In the video you can hear the impeller hitting the block. I assume it is a metal impeller. I put my mechanic's stethoscope and the sound was like a bang.
According to Rick the water pumpis two years old. Manufacturer and whether it is new or rebuilt is not known yet.
EDIT: GEBA 2 years and 8 months since it was put on there.
No knock at idle, but as revs increase you get a metronome sound.
I hate it that it was not known when I had the car apart. Now, all the work has to be done again. Sadness.
Last edited by Kevin in Atlanta; 07-16-2021 at 12:54 PM. Reason: More information to relay
#50
Well, I just discovered this thread. I don't have any WP failures to report, but I would have a question about what I should do. I recently bought an 86.5 with 37k mi. The PO didn't drive it much, bought it with 33k mi in 2008 and replaced the TB and the WP himself. I know that the TB was contitech, but don't know what brand the WP was.
Q: They only have 4k mi on them, but are 13 years old. The car was stored in a A/C garage all this time and rarely brought out into the AZ desert elements. Should I be worried at all about the TB and/or WP? I know I will need to address it at some point in time, but was hoping that would be a year or two down the line. I'd like to enjoy the car for a while before taking it apart.
#51
Well, I bought an 88 a couple of months ago with 5k miles and 21 years on the waterpump and timing belt. The waterpump lasted about a month before the impeller (I think) separated. The car sat in a garage for about 14 years before it came into my possession.
#52
Former Sponsor
#53
#54
In 2030, the sale of new cars with fossil-burning internal combustion engines will be banned in the European Union. What then will happen to smaller subcontractors to the European car industry? Subcontractors who may have one or a few products directly intended for the internal combustion engine. Production of water pumps will cease, electric cars do not need a water pump. Maybe we can hope for the Chinese? Will we have access to fuel for our old cars that are still powered by an internal combustion engine?
Åke
Åke
#55
Åke
Åke
#57
The knocking pump is a GEBA with a metal impeller. I've not taken the the car apart, but this is what the owner has been told by his mechanic.
The pump was installed in 2018. The waterpump is 6-8 months out of warranty.
#58
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1500/pxl_20210716_162928706_0ebf12a8ec02bf1ab5007a0821c460016aefb88f.jpg)
#59
Former Sponsor
Åke
Åke
checkmate1996 (07-23-2021)
#60
Former Sponsor
Even if the failure rate of Geba pumps was one out of a hundred, I still could not/will not install one, for that reason, alone.
If someone comes in and insists I use a Geba pump, I respectively suggest that they would be happier at a different repair facility.
After all, Porsche decided that metal impellers were not an option 32 years ago!
What the 'ell does it take to learn that lesson?
