Oil separator under cam cover NLA
Pretty simple...after a bunch of designing and testing, we came up with an improved oil separator for the inside of the valve cover/covers (depending on when your '93 was produced.)
While this will not repair the terrible design problem with the piston oil return passages not being drilled through in the GTS models, it will certainly reduce the amount of oil that gets to the intake manifold.
And although things have been a bit confused here, (two of my four mechanics out for injuries.) I'm pretty sure I have not seen your email about a transmission.
Please resend to GregBBRD@aol.com.
Former Sponsor
pmooradian (02-16-2021)
Former Sponsor
Your engine is plumbed like a '91 engine.
One of the three different ways Porsche plumbed the GTS models.
Porsche had a terrible time with oil consumption on the GTS models, once they eliminated the oil return holes in the pistons.
Which they never were able to solve.
Ducman82 (02-16-2021)
Former Sponsor
However, since the valve covers are off, the pieces are so economical, and you are missing a breather, it would be almost silly to not to install a pair.
You can call Mary at 714 879 9072 and she will ship you a pair, with instructions and tools.
The valve covers are off on the S4 engine I'm putting into an '89 I bought last year that didn't have an engine. That's the one missing the oil separator. When I'm done with that, I'll tackle the GTS.
Received 1,615 Likes
Looks like it has a GTS filler neck (with the right-side port) and some sort of hose that ain’t the uber-twisty GTS hose. Or, it does and the hose was put on wrong.
Pretty sure I saw it there. I remember seeing a GTS with a VIN close to mine. That was a short time after I brought my GTS here from NorCal. Runs much better on 93 octane than the 91 swill I had to put in the tank in CA.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/88_s4_1f6456f543a04d8b803435892ca5e1835db00281.jpg)
My engine is the same, 92 GTS.
