Hi guys,
After having replaced all seals on the oil pump, the cam towers and having replaced the crankshaft front oil seal, I am still faced with a major leak at the front of the engine.
Have a look at this video:
You can see the oil leak onto the floor at the 5 o'clock position, bottom right of the harmonic balancer. This is on a cold engine, so you can only imagine what the situation is like when the oil becomes hotter and thinner.
Basically I will have to take everything apart again and check what went wrong. Crankshaft front oil seal was flush upon installation.
Any tips to get it right this time?
either the oil pump or the front main seal in that order, chances are good the radial seal was damaged while sliding in the oil pump center gear
NOTE make sure that the gears in the oil pump have the dot facing the block
Thanks for the feedback. Is the "radial seal" you are referring to, the one that sits around the oil pump centre shaft? If so, is it a better strategy to install the center gear first and then press the new seal into place?
Also thanks for the heads up on the oil pump gear dots. I am 100% sure the gears are installed correctly.
Regards
It looks like the shaft seal can be replaced without removing the oil pump. I don't have the special tools though. Is there a trick to do it properly without the tools?
take the front cover off then remove the T belt,
then put a gun on the oil pump and spin it you will find the leak.
NOTE you could have also pinched the O ring did you use DC111 on the O ring?
Excellent tip, Stan. Thanks. So just apply shop pressure on the oil pump gear and let it spin to create oil pressure in the lubrication circuit...?
And yes, I applied DC111 on the oil pump O ring.
put a bolt into the tensioner hole so oil wont pump out.
Also remove the oil pump gear to see things easier before you use an airgun to spin the oil pump
Sounds like a plan. Thanks for the input. I know what to do.
