Noisy window mechanism
Hi all,
I have a question about my 928s2 window motors - I have just had the motor out on one side, cleaned it up and lubed it, got the brushes freed up so now it works really well, very strong action, however now it's all back together the whole thing sounds pretty noisy, it's not binding at all but it's making grinding sounds, bit rattly. I am thinking something to do with there being a lot of play between the tubes and the white plastic saddle part the rides up and down. There's now plenty of grease so nothing is sticking. Any tips?
I'll be doing the passenger side tomorrow as well as that's so slow it's almost not working, hopefully I can free that off as well and make it better.
Thanks folks!
Thanks folks!
Team Owner
is the pinion gear rusted? and now re greased?
Team Owner
I had a window motor that had a rusty pinion gear and it made a lot of noise,
it made a grinding noise.
Thanks, I'll check that. The worm part was OK, can't remember about the pinion gear, will look again now I know what I'm doing. Hope it's salvagable as it;s otherwise pretty good.
Team Owner
UMM I think we might be talking about different gears,
I am talking about the long thin gear that drives the white plastic gear, NOTE this is inside the gear case.
NOT the gear that runs the window lift arm
The play on the white nylon saddle can be reduced by fitting a cable tie around the post and saddle - not too tight, and lubed. I bought a pair of saddles many years ago, only to find that despite them having the correct LH and RH part numbers moulded on them, they were both RH types.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
There are pads inside the saddle holes to take up slack with minimal friction, but they wear out and leave things slack. The other thing to look at is there is a rubber pad in the bottom of the vertical post , which sits on a metal pin on the bottom of the door. These rubbers can die with age and heat and allow the post to move and maybe rattle - check how firmly the bottom of the post is located before you button things up.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Hey Freddy
I am trying to decipher pin outs for the window connector under the dash to hotwire my S2's window motor before traillering my car. What year is your S2 and do you recall the motor wire colours?
David
'85 S2 Euro auto
'89 GT
David
'85 S2 Euro auto
'89 GT
Hi David,
Does this help? I photograph everything and fortunately took this, you can just see the colours although pretty feint
Connector to the motor on 928s2 1985 UK car
HI Freddy yes I think that helps me identify pin numbers, thanks. I will have a go at not letting the smoke out of my wires, David
