Rear wheel suspension torque question
Hello. My apologies for this question, but English is not my mothers language. The locknut below, number 15, should that be tightened to 46 NM / 33 tflb? It seems a bit low to me. I am not sure if I looked up the correct description of this locknut. I took the torque spec that says: 'Upper suspension link to transverse member, upper suspension link to wheel carrier'. Not sure if that fits this locknut. Thank you!!
Yes. I think you are reading it correct. If you are concerned try adding some blue Loctite.
