Replacement Oil Pump for 1980 928S
Replacing the seals on the oil pump on my 928S revealed a rather unpleasant surprise. The oil pump gear is severely nicked in one place and has burrs in other places.
According to PET I need part number 928 107 018 06, but I fear this part is no longer available.
I am located in Belgium and looking to find reputable suppliers for a good used oil pump.
Thanks for the feedback.
Try Van Zweeden in Zeeland.
I checked with my local Porsche dealership. I have the M28.11 engine, serial number 8200513.
According to PET, the part I need is 928 107 018 06.
Porsche says this part number is no longer available and has been superseded by 928 107 018 07. However, PET says this new part number is for serial numbers later than 8210658.
I found online photos of the part linked to the new number, and it looks very similar to my oil pump.
https://www.fvd.net/de-fr/9281070080...-47-49-50.html
Hard to tell if it is exactly the same.
Do you think this part will be correct my engine?
Former Vendor
Good used oil pumps can be found, but you may have to do some searching. Make sure you can return/exchange a used pump, if it doesn't meet your standards.
Former Vendor
They are all the same dimensions, with the same oil galleys. They have "moved" the OD sealing O-ring around, depending on the vintage, but that is of no consequence.
If you don't have the three bolts with the thick washers and O-ring seals, order those pieces, also.
