What fastener is this?
Received 1,665 Likes
900 187 108 01
M6.3 x 16 Called a tapping screw.
They are used in various places. Off-the top of my head: one of the two fasteners for the coolant reservoir.
Also, commonly used for the four under tray holes that are in the chassis when the M5.5 version won't fit because it was stripped.
900 187 115 01 is the M5.5 version and it's used all over the place.
Edit: You'll find one of these two used (almost) everywhere there's a speed nut.
"one of the two fasteners for the coolant reservoir."
Goddamn..ya..I should have mentioned where it came from.
That's exactly it...except its holding up an A/C condenser now.
Are you aware of any fitments with that thread, for a rubber mount buffer, like on the fuel rails/etc?
When back from SD, I want do isolate it from the cabin wall back there, my compressor is new, and has the faintest noise..that amplifies into the cabin with this directly bolted to it.
I had a MUCH MUCH larger noise (that permeated your brain), that was mechanical interference to the condenser coils from the mounting cassette for it..but I resolved that clearance with some pliers, and stopped the harmonic vibration it had with dynomat.
Wheel well liners are another place the M6.3 Captive Washer Hex-head Sheet Metal Screws (that's what I call them) are used.
There are a number of items that use a rubber buffer and an M6 bolt: ABS pump, PSD shock frame, front condenser stays (OTTOMH).
900 187 108 01
just getting back to this project..
Would THIS longer bolt fit the requirements to replace these?
I need to mount something here on an isolator, so I need a longer bolt:
https://www.autozone.com/nuts-bolts-...ece/848396_0_0
The bolt at the top of this thread is a ‘self-tapping’ type for use with speed nuts. The bolts you just posted have a machine thread designed for holes with machined threads. You don’t use self-tapping thread bolts in holes that need machine threaded bolts. Not more than once. Machine-thread bolts can go into speed nuts, but, not very well.
I don’t know if what you posted will work in your application.
If you just want a longer screw than what the factory used, belmetric has a selection that will get you covered. Here’s a random longer one:
https://www.belmetric.com/63mm-c-10_...nc-p-9507.html
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAoHCBYVFRgWFRYZGRgaGiUeGBkaHB4aHB0cHBwdHhoeHBocIy4mHh4rHxwcJzgmKy8x NTU1GiQ9QDs0Py40NTEBDAwMEA8QHhISHjQkISsxNDQxMTQ0NDE0MTQ0NDQ0NDQ0NDQ0NDQ0 MTQxNDQ0NDE0MTQ0NDQ0NDQ/ND8/PzQxMf/AABEIAOEA4QMBIgACEQEDEQH/xAAcAAEAAgMBAQEAAAAAAAAAAAAABgcBBAUDAgj/xABBEAACAQIEBAMFBQcDAgcBAAABAgADEQQSITEFBkFRImFxBxMygZEUQlKhsSNicoKSosEz 0fDh8RYkQ1Njc7IV/8QAGAEBAQEBAQAAAAAAAAAAAAAAAAIBAwT/xAAfEQEBAAIDAQEBAQEAAAAAAAAAAQIREiExQQNRIgT/2gAMAwEAAhEDEQA/ALmiIgIiICIiAiIgJzeM8Wp4amalU2UaAAXJJ2AHedKVf7VMWfeUqVzYIXt5sxUfkp+syjzx/tGxBa+HpUwo+7UzM7f0sAPQXkq5Q5rXGqQy+7qrfMt8ykA2ujdR3G4vKcVvrJRwDiRFipyun UaX8/8ABHWcssrj36q42LjmZDaXO6NTDIhZ9mGYKoYaNrqdD0tN7g3MorPkdAjH4SGzAntqBY/rOkymto3PEliYBmZTSIiAiIgIiICIiAiIgIiICIiAiIgIiICIiAiYvMFoGZVHtSX/AM0h/wDhUfR3/wB5ZT8TpBmQ1EzquZ0zDMq73K7yted8SuKFOuquqrdWLgKbXurZbk21P01kZZYz2qxlt6Qpd 570KwRr3PynrisLTVCwreK2ZVy3zjW4BGx9fy6x56xLjJdhuL6eoM5cpk9Nk8qTcLxGWtVQr lDvmv8AdzsL3GlhmFtL7yQUXsRb5eshIRnpirbK1J7DQ+JT4kF+4HvAD5gSY8Of3gV8pAPUn fQHT53GttpfKTF4v1mll8A4h76kCfiU5W9RsfmJ1ZC+UmK1mX7rJr6gix/MyaSsMuUbPGYiJbSIiAiIgIiICIiAiIgIiICIiAiJgwMEzm1+NUVR394re7vnVCGYEG1so1v fScnmHmkYep7vIWATM7A/BmuE066gk+Q0vKnONA8AzggnO17gg6hgbXB1N/IgznlnrqNk+rJ4xzrlpKaYCMzamqLhV7hVPiJ2Av8AWR7i3MzvXRs1TKotak+Vbk3DkffuOh HQ7EyL01b36UXBRQu5Jtb4syk7jXNbsGmzhuG1GqVqdUHOvgJTUZiSFbyBZQb+ZtIvK+1e8Z 49G4s5ao2dP2hY3KgNm3N237HbbpNbDI7JkUPZjcDxEZtiLdP+07FPhINLLVKhi1ri18wGZW FhbVS2/SbFOqlMogGuRW3JsykhtSNb5V+snjGcq5nDOA1G8TtfIc62ykqt7toeoyi48tfPvYbkpKiK6 5URrjxH4WUWcC3TMrfITnf+I6lJ6iJYA1GvoD4X8QAvsBmYSNvxjEZPdXYqLm5Ogv8A51P1l T+N3dpBiqdA0Xw5e9R1yoq6AlDnp6jrmQD0Yzy5Xqj7Otjfcn1JN7/O8jGERkqUqjMbo6sbdlYEj56/WTmhhEpPWpqQAlTw3tfI4OlxvZkv5Z5Ulk7cv+ibqRcvPapTP8S6dzc6/L9JOJB+VsM5rBsrZFB8RFhfYAX66ycSsZpOG9dsxES1kREBETjce49SwiBqpJJ+FVsWY+QJ2 8zA7MSr8R7Sqwe6YZWp3tbOc4udyQLD9POTflvj1PG0hVp3H4la2ZT2NtD6iTMpR2YiJQREQ EREBERATi8wY56aqtFc1RzZdVAUD4mbMQLdPnOzPKrRVhZlDDsQD+syzcFYUeGfaa9U4zEFL EK4VgELLqguTbLlYMn8/UT25VrYam9YVmplUvRZiM19CUIIGzIXGnRVHSSjjfCsDT/b16aIvwtZQFa58OdRo2W7EE7XM08LyfhmrCvSCHDvT1pr8JbTKykG1rX085Mx0fUSpGicpUB 3oOURz+BQShI81cr/ACecyHq1sK9RFPhplGZQdCmlz53UNJzwnlOlh69SouqOoCoy3yEbkMTqD6ad51uGcKpUFZKS 5VZy5FyRmbU79PKOIr+ty3iK9DD1UysXdHZb5SqsNT4t7A7frJTT5RpriaeIVjZEK5GAYMSC ASbed/UCSUCfU2YwVb7ReBCky4imtlc/tANg/Q/P/EhCa5pfnE8Ctek9JxdXUg+V9iPMbykuKcOfDVXpONR8LWsGU7MP+d5zzx+x0xvWnGqDcSyuW 6pbFUnIFnTxXF/EEve/reVvU3lo8mYcmon7lO5+YAHpvNnxP6+xPxMzAmZ1SREQEREDAlOe0bFl8ay30pqqAf3N8yW/IS45SXPC/wDnq38QP9gmWtnrh06liCOn09CO0mPAuN+6HvEFgB416EDcf9ZC1m3ga+VrX30sdjfv5TjnL e5665YzS163OVOwNJGe4vc2UfXW/wAp0uC8bTEXFijjdSb3HcEbiU9y5ifB7ohlKEhQ24UHVL9cpv30t2kkwOKamyuu6m48/wDoZ13dbee5cb2tWZmrgcSKlNXGzC9u3cTZmy7UzERNCIiAiJpcUxy0KT1WNgqk69+g+sCsf a7x27JhkPw+Jz+8RoPkP1ka5E5ixOHYojXpak021UHuvVbne299pwuLY5q9V6r6l2J+pM7HB MPkp5ju36TlarSzsHz8hsKtF1/eQhx6kGxt6XkiwnHsNUtkrIT2Jyn6NaVCsETJnTivIGJSNCoyG6O6dsjFfyBnXw3NWLTaqHH aoob8xY/nLmcONWvONzBwCli0y1BZl1Rx8Sn/ACPIyMYXn5x/q0FPc02I/tb/AHnYwvO2Fb4i9M/vqSP6luPrN5Ss1Uf4f7NMtQNVrBkBvZVIY9r32k84fw9KK5UG+5O5nzheK0KnwVUb0YX+m83 Zs0MzMRNYRPktbecviPGqNGn7xmzKWCrk8RLG9gLeQJ1PSZbodWYJkL4vzkEektLIA2rmrdS OyqAfi89hcecjtfm12xDuHqqtrIgy5BYEEMNy19byL+kiphasfFcVpIjuzrZPiynMQegyjW5 7Sq+cQtXECst0SoosXGU5hoQRfQ7aeYnJHEXFJk8AB8V0BVipJvck6m/Xe9/KfDB6iBLs2VdM12uu4Nz09TtOeWeV86VMZO68OI4ZKa5veqbGzKB4rH7wvoR+h+s4SYg5ze7 ADcdQdj+kmWC4A7LmqjNYZHAAOh0Av0J6HobTrvyMAhdbBQmZCxGq7gWHWxjVk7rry70hlKq VejiDoGurgk5sw8FRguoG6MbfjkxwaZgGsQCLi+h/7dR6zkcxrR+zMEe9RGFRlGgUG1Njfr8SE+g3nT4ZUHuksbjItj/KLflN1yx1Hj/b/N0m/J1VsrodlII+ehH5STyK8sN+0I/FTB02OXKp+d7yVTp+e5O1Y3c2TMRLaREQErD2u8byquFQ6t4nt2voD9PzEsfFYhaaM7GyqCT 6AT888R4gcViXrv8AeYhfJRtb/naTWxzsNhc7onfU+gkndwg9NhNHhdK5ap3Nl9BMYytdrDpOftbaxXrHVi+U7DWwF5sYH7Q9F 2pUXrWNs65XZLdfdoxf6gXtvObxFVdCRe6sNOljoSfnaTDlTgqsFcEqANCDYnbqNhKmMvbnc rHGp4q7ZGV1a2zqUY9zlYAibIIkr5pwtMUS7FmdQAjMbka6AE9N5DxjsvkQbg77TMsf4vHL+ vaw7zAadWrxDCYimzshp4nS5S+Vz1OXZb77CcmoBeRpe30qjsPpPUc418HZaVnDFRkckjQ7L r4Sb2uPLtPHNYX7Tz5HwP2riSFhmSjeowO110T+8g/yzcfWXxeVJiQCRYkajt5T7JicDjuPrqy08MmeoRdiR4FHTM1/CTqRofh87zrbqIcTmvmdbYnDAOpylBUBFizAZlA6aG1+/wCdcpjA4WmjOoIsQWtZz90MLXU9PW3eSbB8CbEJVqVcTZwzOiN4f2hBzFiTocyspA0GXTS03 OB08LVwlT3hpoa1yrEAMrqTmFxro6Z/LP5Tncbl3WzLXiH4D3mIqOguHUeAVDc5gCArZtdcjL65Z94HBvURiMwfP4Ra4uD4lY7bGxv+ Gdl66EfaUS9V6ZLknTNdTsD8QqJv29TPTiWIcUhXRCtNqiNexykN4bE+akqTufI2manyNuVv rXrcIDIhtkcDMADZt7OunZgpv+9tOhSrorsgAIViLdCjKCNLa2LsP5RN9uV8R9pw+bxUyrCo yn4QfFY3trcD6zv8L5TSlXq1WIdaigKrLqtt9euk3jazavf/ABJU+zmigAvTILAWbOlrG481B+ZnExvH8TUQIS9lUKCScvoL7i07nOPBRhK+VRam/iTUm34luddCfpaR9RdTfvMt166Yz6+uX8GGxSq7HJUV6bjuKiMn1DZWHmokrwFNVpqAR4cym 1h8DGxPmVK6yJYCsUqo+vhqKfoQZZvJiKcRVBVSModbgEgkgHXpb/Mtx/bHllpv8nUmzO5UhcoCkgi9ySct9xp07yWzAEzOjMZqaZiIhRERArv2ucZ93h1oKfFUN28lG3 1P6SuKbYY4YIuf7SWsPwFTa9+oIAPreXHzfyyMYF1UZQRYqNb21zbi1vTWV1W5Fq4YvUYFgl sgVWYsCbH4b5cu+u8mt6aaplQKOgsJorVyD/TV2DE3YE3DKVIIuL2NiDuD3m0uIF7EEHz0npnB7TlvTbJXBpVTqhUDNpm3tqDcX9Lehlj8K4 glLDBmOiLqBvcaW9b6SJtRVtwPpPSqCaZp5jlsBb0NxL5M4vvi3GnxD/hQG6r57XPnaMTw5zhhXt4S2W/mBrOKcHUT4Tcdj/vJ/gub8OcGKFXDtmC5cosVLdGv0N9dRNllTqoVgVzMPLedFjczywyBQbdTPUSL6uNLjGJyUz3Mn nsf4P7vCviGBzV2Fr/gS4W3kWLnzuJWOPpPicQlBPidgq9dWNr/ACGvyn6I4dhFo0kpKLLTRUUeSqAP0l4wramrisBSqf6lNH6eJQdPnNuYMtKIcR4Bw+mymtlU VGslNjlQObBioHwlrIDrbQdTr5YDkSij1Q4zUWIakoZgyX+MG2+oFjIB7U+Oe/rmmvw07r6m/iPoSPyE2+SOdMTTQpU/bIg8GdiGGvw57EkAbXB2k7jeKfcC5Pp0KdWm9qiu5IJFiqkAZb97gm4tO5w/hyUaKUUF0QZVDWbQa69zecPAc74d7Bw9MnqwDL/Ut9PWSDC8QpVBenURh+6wP6bRLPjG0JmYvMyhwuauCjFUGT763amezAaD0OxlL1KbIWR1Ksp syncEdJ+hCJFuaeT6eL8a2p1vx2uGHZgN/XfSRljyVjlpTeHF3UDqw/WW/wAm0fFUboAq/PUn/nnONwP2dsj569RTb4VQXue5J/ST7BYNaShUFh17k9yepiYsy7y22ZmIlsIiICIiAmLTMQOVxHgWHrj9pSU+drH6iRDifs4GrY epY9Fe4H9Qv+ksOZmWSij+JcGxOGuaiMFH37XT5stwB62miuK0BI0OzDUfIjSX7I9xXlDC4g lmp5HO9Skfdv5XI0b0YEeUm4Ru6qlaqtsRPsKJ3uMezzEprh6iVx+GralU+Tr4T8wJEMa9XD NlxFOrQP765k8rVE0Pyk3C/G8v66U8cZUyIT5T4wuKz/CVb+Eg/l0mnzOHTwOrIeoYWOvrJ43bZZXa9k/CTXxrYhtVoAkfxuCq/RSx+ku+Qv2X8HXD4FHsc9f9o9/MWQW6AIB9TJpO0TWJxOa+LjC4apUJ1tZP4joPpvO3Kb9rHG/eV1wyHw09Xt+I/wDB9It0RX2IqF2LNqzG/wAzJTw7D5EVep1M4nDMJnqC+y6md+vWCi/XoJyqrXuJgDW/Xv1+s5Nasw1z2J/x2E3PeVhSRzQqZGN/e5GcFeoyoTrbqbbzONZyn11qPFMQhuteov8AOSPo1xOvhedMUnxmnUH7y5G+qaflIth8Yj3y nbQ6f4/7ET3BEbsOqnWH9oCae8oOO5Qq4/uKmdnDc2YSp/6oU9nBT9RaVawEZpvOt4xdVCujC6MrDupBH1E9pR9JQDcaHuND9ROzwXnmuuJo4YgVVqVVQs xbOobQkG9iF+LUbAy8c9ssWxEwJmWkiIgIiICIiBgmAZXXtL5mfDZadFyrMpzBbH4rAE3Bt1 tacHg3tDxdBVbE0zVpN8L2yvobEA2s1vrM2LkiRzgXOGFxQASoFf8AA/hb89DJEJozPDE4dKilXRXU7qwDKfUHQz3iBAOO+y7CVrtQzYap0NPVL+aX0H8JEhOO5Px6N7 murYhNkrKWZgLdL3Oh+6flL1mLQzTl8uUXTDUUqCzqgUj00F/O1p1YmDDXM49xJcNQeqx+EaeZ6T8+JVLu9aoSWYljffXv5yee17jWZqeGU+FfE5H4joB8gf7 pFMTSwzpRWg7lz/rIw0FtcysNwTYW8jIyb29OF0cqFju5ufTpPCtVzP5XnQxA8JA7TmPUVUy+7uxUqWudDnzBxb Y2AQjUWkT0yjWx9NXZGubFirDoLbfUfpLD5Y4OygOrugNtEYjNbqbb79ZX+Dq5yEy2OYMTe+ ijaWW/FkoUVdr2sAoUXJJGk6TqIs20ubsIiZagJNR3szHdgEO562sv5TgYbiSo6uVVspuVcAqR1BB7 ieXEOKvXfM2w+FdwB/vtPni/D3RKbkWDrmU9xeZljvsl07mO+x1EV8OzI5PjpHW2l7q3QD/PSckjWaXDxclug/WboOs56dNlWrlUnsJ0PZPgBXxdXEsoK0lARjrZ3vt5hQf6/ORnmHFZUyg27/5lvezjhH2bA0riz1B7x773cAqD5hco+UvCFvSViZiJ0SREQEREBMEzM4vNfEPcYWo/W2VfVtP0uflAqvmPFjF1nLgFFdglgAct7asNT8It2vOZiqNVkRA5dKYIRGsMoJubEefeeuGF lHfea32h7FwQQGsRqbXvqSBYDS2p39Jx3dq1NduXjKYU3KsjD/mjCdvgXPeKw1lz+8Qfdqa6eRGoiniVcWYDXodpr4ng6NqvgPltN3YTSz+A+0XDV7K5905/F8P9XT5yY0aysMysGB2III+on5vXl7EM6JTGZnYKpGwJNrm2wHX0l/8ALvBkwlBaKEtl1LNuzH4mPa/bpLxu2WaY5hxq0qQLX8TqoVblmGdc4UDU+AN8pGuBc2JTNSliHqeABlZkZyENrZ2QG51Gu3Q HSbXtAxjLTREpMz51YOfCiWYaGoRoWsRYa2+V4nzhSxJH2qrTF/ClkuqW1IuT4nHS5AGo16TMt+xkWzQrK6hlIKkXUjYg6giesgnI/Gq1Vyj1FdAgyjKEbNYaKBa62zdOl5OxNxy3G2aQPnPkk4tzUXLfKAABlIIvc363JkEPLVTBq XqizFiuWxJygAhrgWym9u+hl7z4emCLEAjsRcfSLGKHTEKes+zY9pbHEuUMLWuTTCMfvJ4T9 BpIdxH2eVkuaDhx2Phb6E2/OTcaqX+om2FRulj3G89OIhqiBM1gDcW0sbW+kziqFWi2WqjIegcFL/wltG+RM+BiRswI9ZN5Q6rmU6boRcBh22MsPj3M2DxOGCBHDgAIpW2Q6dQbEW0kUBB7GfQQRM qcY+cOmVbCfd7CLTU4pXyIfOZ63XTV4LgTjOIUaVrrnu/kieJyfI2C+rCfogCVP7FuFn9vim6n3SedrO5B7aoP5T2lsTrjOk1mIiUwiIgIiIGJXPtP4hd qeGB+7ncfxEqmv8ryxpR/GOI/acVUqg3Quch7ongQjuCFLD+OTldQnrUqHKp8hOPRJAYM+QFgcpuL262AsSL/AJzs18QiWLi4vqBbXXz0kt4JRw2IS6oN7EEAMD5+ok4xuSvVxiFggDbfEVy677X/ADnUwDllOtwDYf8AWdnmTgCU1q1GW6JRJQbeN2FNATfYM4Pqs5eGUBR4SpOrAm/i6kfu9pmXTMbtJuRsLnxStbwojMe19FUeviJ+UtCQz2c4eyVX/E4Ueirf9WkzlYzpt9RTnrA4irRC0mRUXxVC185tbKFFrW3JuR0kK41WrVKSBc9d75Vz5VSmb eErTQgM3qGI85Z3HMBSr0mSsGNMeIhSwPh10y6n0lYYcKyvTpJUpDocgpsR0DFvGbje1/lvGXTHO4FXFKqpqoxdWBIRrm6AuR2DWvfbtprLqweIFREdb5XUMLixswuLjodZROHARrUnYL cAM2inYtp97rrtLf5SxjVKPiqJUKsQCtr5L+DMBsbSMLrKxeXclSCIidkMRMxA8a1FXBVlDK dwwBH0MinFeQcNUuaRfDuf/bN0v/8AU90A/hA3kxiBTPFOScbQuVRMQg+9SJSptremxIv6MZGk4llco5NNxulVTTYf87z9FTn8V4RQxK5K9 JKi9MwBI9DuPlJuMp2prDMzkBVJJ2y+K/paR7mWuQxUgjLqQdNhtr1lj8U9lSoTUwGIei4OZUZrqCNRZh4l+eaRKrwHHPVK4ig/vUbMKi2YOVIIvY63/FYeczjrxsyv1cfKnBxhMLSoi91W733Lt4nP9RM7U8qJJVSwsbC4HQ21H1nrLYREQEREBERAj vPHFjhsFWqKbORkp987nKtvrf5So8BSCrYbCyj0UW/xJT7VuJZ8Rh8Mp0pg13/isVp/qxkdopZQJGf8bj68U4TWxVTJSQvkGZrW0Gw36+XlPfCGthnvZkYCzK6kX8mU/rOhwXjD4RqrogYuoXX7pF7Ed99pw8bxCrWYtUYset94xs0zKduxxfiT4pFDgKotcKTZ7G4vr sDY28hNe2k3P/5/u8PTd7h6p8CjYKtszMT3uLATTqX1tvOdy3VYzSz+RaGXBoTu7M3yLEL/AGhZI5qcMw/u6NNPwIq/QATbnaeJYMrvmXCV0xBqPUplHPgQKMwVbWzZr+etj/iWIZX/ALQK+C3dfeYhbKMhuyLucwLBbfnrMy8EQ40HD3yrkH4GViCejFdEGg00/wASScgY5EYL7koCopmpfwjIpYXvuNTqevrOWafvsPmVGsNBcqbEDMAFXyHUzh4Mu6ujuRZWY pf8AJzN0A/3M4W61XTHHc0umpx7Cro2Iog9jUS/6zOG41h6hy069Jj0CupJ9ADeUJMJ32naZMuFj9GgzMhns64y1ai1J2LPRy6nco4JS56kZWGv lJnKl2giImhERAwRFpmICIiAiIgIiICeGJrqiM7GwUFj6DWe88cRRDqytswIPoRYwKDbiSVq 2KxlfMHrOooL0CKct2/lVQPMGbdKurDwmT3EezLBuDmaqWOzh7WHQBQMtvlIpxP2WYimWbC11qL91X8D+YLDwk/ISMsbW49NCYIB3F5ysUcZhTbE4eoo/Ey+E+lQXU/We+F4tTfrYyNaU6dWsWy3JOUZVuSbKNgOw1P1mxwzDe8r0U/FUQH+EMGb+0GaiWOo19JIuScPmxaH8Cs35ZR/+pk9Pi0BPh3ABJNgBck7AT7kd54pVGwVVaVy1hcDcqGBYC3l+V52Qh/M/Oz1S1PDNkp6g1Bo7/wn7q/K58pCVuNbD5zxNRhoQR66flAZm01PkJysytdsdRLuQaj10emauRSL+7Cakj01v9ZF+Y63u65 yAhdRlGl7n77AC+vTb0nrwgV8NWFTI9KmfiqOfdJ4tLK7kAnyFzrtPXmB8M7/ALOo7kG/gUkvpcAu3U6/CG+Uy7vTJccfrn4MllGmo+U73C+Cs5BYEsfgUd+k52CwVVyCb0VudNGY3G5JN266GwvbTaWF 7P6KI7p4ncrmDuczaGzeI98w2tHHJOX6b6jrcjctHBU3Ltmq1WDVCNha+VR3tdifNjJVMRO0 mohmIiaEREBERAREQEREBERAREQExaZiB5vTDCxAIO4IuPoZE+M+zzA4glvdGk53ekSgv3Kf AT55b+cmEQKe4j7NsXRu2GrLVUbI/ge3kdVY/wBMl/IHCKtGkXxCFKzHLlJBsgOm2gJOu/QSYxJ4xu2Z51EDAgi4Oh9J6RKYh+M5RzElGW19Ay6jyzDeaL8r4imrsKqqApOWmCGNvMjtJ7 MEXk6jNKixvD6dRgzqXYWs7sXa3bXQC+tgBPunwymBdUVTvcCxuDcbefSTteV6Sm6s6/NSB6XWex5eptbOztbu2nntJyxy+OUwu+6gVDCszhVFyToBuZOOXOB+4u7m7kWsNlGmnmdN51 cJgUpCyKFHW259T1m1Kxl+ukxku2YiJSiIiAiIgIiICIiAiIgIiICIiAiIgIiIGImYgIiICI iBiIiGEzETI0iImhERAREQEREBERAREQERED//2Q==[/img]
Fastener and Clip
Fastener and Clip
Fastener and Clip
Fastener and Clip
Jeff, I have these is 18mm length and the washer is 22mm in diameter. If mine would work for you I could send you some. Although they don't look any longer than the one you show.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/pict0263_4ca38f4e915ccec37e1dcc15be401761df1c292d.jpg)
TY Jerry, but I need about 30mm to be certain what Im doing will work.
What an oddball fastener to use, if I must say. Any reason a regular bolt would not have worked here?
Jeff, I'm not quite sure where "here" actually is for you, but I bought these to include with my Early Belly Pans mainly for the two wing mounting points where the screw goes into the bottom of the front frame horns. I have found on my 82 that the two screw holes in the frame have been wallowed out enough that the 5.5 screws that I have for the other holes are too small. Too, I think the holes in the frame may have been threaded rather than being intended for self tapping screws.
