928 Forum 1978-1995
Sponsored by: 928 Specialists
Quick Distributor timing (rotor) question
Old Mar 12, 2004 | 10:22 AM
Greg86andahalf's Avatar
Greg86andahalf
Question Quick Distributor timing (rotor) question
Hello all,
I need quick verification-
On an 86 with the crank at 0 TDC firing, the right (US passenger) distributor rotor points to approx 3 'oclock position correct?
Where does the left (US drivers) rotor point at that crank position?
Thanks,
Greg
Old Mar 12, 2004 | 11:31 AM
Rez's Avatar
Rez
WSM: 15-132
1. Turn engine in direction of rotation to TDC (Cylinder #1).
Note: Both distributor fingers point left in forward dirction in travel (Not sure if this is 3:00 or not).
HTH
Old Mar 12, 2004 | 11:43 AM
Greg86andahalf
Rez,
Thanks. I saw that pic of the one rotor last night, I should have read the text where it refers to boths rotors pointing the same direction. And yes, that would be about 3 o'clock position as you face the car.
Thanks again,
Greg
