WANTED - Shift valve body
I have one from 83 auto. Would that be the same? Not able to look for part number just now. It's on a trans that had catastrophic revers clutch failure so may need to be cleaned..
Former Sponsor
What you need is a rebuilt unit from Porsche. Autoatlanta offers them here. Buying a used valve body is a crapshoot.
The problem is that I am in South Africa and with our government screwing up the economy on a daily basis , buying parts from overseas is crippling.
Former Sponsor
And BTW, government screwing up the economy is not isolated to South Africa...ours is doing a spectacular job at this, too!
What is wrong with your current valve body? Total failure of the valve body is rare. Is there something we can do to help? I can't do a valve body rebuild in the dark yet, but I'm close....
Thanks for the reply. I would love to try and have it repaired , but according to the gearbox specialists it cannot be repaired. One of the pistons broke and it has caused a pit mark inside , and so according to them , it will need to be replaced.
I hate hearing that , especially after being in the trade for 30 years.....I believe anything can get repaired. The one thing that I have never done is work on gearboxes which is rather strange as my father was a gearbox specialist for Borg Warner.
The car will not change up under normal driving conditions , only under hard acceleration and if I come slightly off the throttle at lower revs.
Former Sponsor
K1 piston?
I've got an entire box of valve bodies I use for parts. I can probably find the appropriate body and a piston....you could then transfer your remaining pieces.
If you do , please let me know what you want for it and if you can 'gues-timate' shipping.
Former Sponsor
A picture of what piston is damaged and the corresponding bore would help, so I can get you the correct parts.
Former Sponsor
I'm guessing that the spring broke, ruined the plastic piston, and damaged the bore.
While not super common, I am seeing it, more often.
Springs break, with age and use.
The gearbox is assembled and the gearbox shop says that they will only have time to strip again next week.
I think you are 100 % correct on the spring that broke.
Perhaps , if you can work on the valve body part number for the valve body. That would be greatly appreciated. Trying to locate a valve body is what is currently giving me sleepless nights.
