Fuel: Check, Spark: Check...
Received 1,638 Likes
Update: As stated before I got the car running by following Stan's "foot-to-the-floor" and fully charged battery recommendation. Coming out the next day the car would not start again.
... Next day. No start again and have to use the foot-to-the-floor.
... Come out the next day and the same no start situation again.
Sounds like it starts but *only* if you use the foot to the floor method?
When you mash the pedal to the floor during cranking there are no fuel injector pulses.
Thus, you either have something leaking fuel into the intake system or a weak electrical system. Or both.
Edit:
What happens if, a day after running the 928, you attempt to start the 928 but *immediately* use the foot-to-the-floor method *without* first attempting a "normal" start with no pressure on the throttle pedal?
Team Owner
did you smell the vacuum lines for fuel?
when was the last time you put in a bottle of techron?
Ok. Sorry for the confusion. Dave you are correct in that it only starts using the foot to the floor method when cold but it does start every time. It will start right up normally once it is warm.
Stan - I've not ever used Techron. Yes I will go get some and put it in.
Quick update: When I was putting the Temp II sensor back in I looked closer at the wires on the connector. About an inch down from the connector the insulation had worn off the wires and they were exposed. Looks like they may have been touching. I cut back the insulation and separated the wires. For tonight I put electrical tape on each wire to keep them separated. I wonder if this could have caused the Temp II sensor to malfunction. I think I will try to start it normal again in the morning and see if this was the issue.
I have not smelled any fuel when removing any of the vacuum lines. I think this would only come from the dampers or the FPR right? Since these hold vacuum I don't think I have leaks here.
If the car does not start right away tomorrow. I will not start it but will let it sit for a few hours and then try the pedal to the floor method right away as you suggested Dave.
Thanks for the help guys.
However, if your 928 starts normally tomorrow then possibly your electrical tape fix has worked. (The proof is in the repeated tasting of the pudding.)
The foot-to-the-floor method is what you do when you think the engine is flooded with fuel. If the engine is not flooded with fuel then the foot-to-the-floor method will not start the car. So, if, after sitting overnight, and thus residual fuel should have evaporated, it starts with foot-to-the-floor method then fuel accumulated in the airguide overnight.
If it doesn't work as a result of your TEMP-II fix, I suspect that with my test it will not start and that your problem isn't fuel leaking overnight. But, let's do it step-by-step.
Next question: have you had your LH computer rebuilt? If so when? And by whom?
This morning I went down to the car. Leaned in the window and turned the key. The car fired right up. I have to say it must have been the Temp II sensor. Whether it had come loose a little and affected the ground or whether the frayed wires may have been the culprit. I'm not sure but I do know that they both were a problem. Of course I won't really be convinced until I fire it up again tomorrow morning and everything is good.
Thanks for everyone's help on this! My 928 would not be on the road (and I'm not just talking about this small event) if it were not for this forum and the great people here. Thanks guys!
Now, what is the best way to fix my Temp II wires? Should I just buy a new connector and splice it in? This seems like it might be the cleanest option.
Interestingly when I went to take out the Temp II sensor it was not very tight. I noticed a little shine at the base of the sensor. It was wet with antifreeze. I wonder if the sensor being a little loose did not get a good ground and was not functioning properly. I'm going to put the sensor back in tonight and see how she starts in the morning.
You'll have to splice. What I might do in the same situation, if the actual copper part of the leads is in good shape I'd tape them or use liquid electrical tape and re-shrink wrap that branch of the harness (and use a new connector and boot.) That avoids big ugly butt splices.
If the copper isn't in good shape then you'll need to butt splice. In those situations I use the marine-grade solder-shink type splices that combine solder and heat shrink.
https://www.masterappliance.com/sold...jar-lead-free/
You used to be able to get these in packs of 5. Not anymore apparantly.
Roger has 2-pin connector kits. Or you can get them hereL https://eagleday.stores.yahoo.net/connectorkit.html (and order the angled boot not the straight one.)
There are also 'pigtail' connector kits that have connector and an inch or three of leads.
Thanks guys. I started the car again this morning. Started up no problem. I'll get the electrical connection fixed and drive it a bit before we head off to the Badlands. I'll check for that crush washer and make sure everything is sealed up well.
Thanks again for all your help and expertise.
