BLASTING INTAKE
HAVE REVIEWED FORUM POSTS ON BLASTING
STILL CONFUSED
MY INTAKE APART AND WAS GOING TO TAPE OFF AND GLASS BEAD
THE INSIDE ID COVERED W SOME SORT OF PAINT THAT IS FLAKING OFF AND I WANT TO BLAST THE INSIDE TOO
AM CONCERNED ABOUT DESTROYING MY ENGINE
HAVE A PRESSURE WASHER AND BORESCOPE
SUGGESTIONS?
ANYONE TRIED DRY ICE BLASTING?
I don't think anyone could convince me to get mine done, which is a very good excuse for having a dreadful looking engine bay
You can blast the inside with anything appropriate to the material.
Just make damned sure you get ALL the residual media out once it's done.
It's the leftover 'grit' that will destroy the cylinder walls.
And posting in all caps is considered shouting.
STILL CONFUSED
SUGGESTIONS?
I rebuilt 3 engines ruined from this, last year, alone.
Send it to Donald. Although I have not had him do an intake, he seems to understand all the issues.
To recap; you must have a LOT of air, like 175cfm worth of air. The most the compressors at Lowes and Home Depot and Tractor Supply and Northern Tool will offer is 25 maybe 30 cfm which will not be sufficient. You 'should' use light weight blasting media, the lighter it is, the more it costs. You need to be ready to spend $1.75 per pound for say a good Plastic, type IV Acrylic, and have at least 500 pounds in the system, and, an enclosed continuous recycle system. You should go over each manifold by hand with a small steel pick and chip away the coatings, (GTS manifolds this process takes 5 hours). You should have a small tool to hold the Manifold in place like this Rotisserie I built for just this purpose. All this considered; we have up to 2 hours in labor costs for an S4, 5-7 hours for a GTS (both including Cam Covers).
You should never use chemicals to loosen up the paint as you likely do not have enough air to remove the softened and now hardening gunk. You then likely will want something sharper so you buy Alum Oxide for way too much money and it has a much harder MOH scale and takes more air to move it so it comes out slower and you become frustrated and then proceed to the dishwasher. When this all is done, you may have 18 hours in your manifold and it looks like garbage -- completely not ready for any paint or powdercoating.
Greg, send me one, I'll comp you so you can 'see' and evaluate,
Would it be OK to tape off all the S3 plenum openings and just blast and paint or powder coat the outside only?
USA S3 "organ pipes" intake (1985-1986.5)
The oil control rings were "sanded" flat....virtually nothing left, with #1 cylinder the worst.
The #1 piston was covered with really thin scratches down the walls, which also damaged the bore. #1 cylinder had crazy wear 90 degrees away from the piston side skirt surface (away from the thrust surface), where there is never any wear.
Ordered 1st oversize pistons (100.5mm) (the only oversize Porsche offers.)
Took it my machine shop and got a call that the wear on the non-thrust wall was too deep for the first oversize bore diameter to cure.
That's crazy and simply can't happen, under normal circumstances.
Guess what? The intake manifold had been off this engine and got bead blasted to look "better".
We're starting to call this intake manifold cleaning and re-painting/powder coating "job security".
Fine scratches above top ring...which means whatever scratched the piston originated from the combustion chamber side. Note the scratches below the rings, on the skirt. Whatever did the scratching above the rings was fine enough to get past the rings.
Almost completely flat oil control ring on left. Normal oil control ring on right. That wear is not normal, even on extremely high mileage engines.
