Aluminum Belly Pan question.
Nicole the problem is making a trap door that is simple , easy to use and does not compromise the strength of the undertray or significantly increase production costs . Oil changes for many is a once a year task ( 12 months --15,000 mi ?? ) , book time for R and R of the undertray is 30 minutes and affords an opportunity to have a look around while it is open . So if you twist our arm long and hard enough we could look into it further but for the time being we are trying to get undertrays back on those S-4 s that have been practicing unsafe speed ........
I buy all of what you say Jim. And it applys especially for those who have a garage service their 928. The person who does their own service will really appreciate the trap door design because getting the pan off of a car that is on a floor jack (and jackstand for safety) is nearly impossible. In other words, we take the pan off because we have to, not because we want to. I would really like to be able to do an oil change using ramps or a floor jack without having to take the belly pan off. It would cut my "under-the-car-on my-back-time" by at least half. I can do the oild change on my A6 with a floor jack, because there are no fasteners on the back of the belly pan, so I don't have to go under the car.....just raise it on a floor jack to get to the oil pan and filter.
FWIW
FWIW
Great idea, but I think the biggest problem would be making the door big enough to change the filter.......you usually need a filter wrench and a couple of hands up there to get it all done........may be a bit much for a trap door to handle......
Mike good point especially when (if) you spill oil from the filter on the top of the undertray . Gretch ....maybe that is an answer make the entire undertray a "trap door" hinged at the rear ??
I have a home-made pan of 2mm thickness, flat and no holes. To change oil I loosen the front, let it hang by the middle supports and drain into a flat store-bought oil drain container. Works fine. A door would be OK but would likely drop the ability of the pan to dissipate stress, and I won't be doing that.
It gets easier after a few installs. The hardest part is keeping track of all the screws and washers. Also, I found installing the lighter weight "factory belly pan" is easier on the arms than the aluminum version.
My biggest complaint is that with the front end only on jackstands, the rear pan must be removed before the front belly pan can be removed. This seems silly if your only doing an oil change.
