928 Forum 1978-1995
Sponsored by: 928 Specialists
FS: 37mm spacers
Old 05-25-2020, 08:54 PM
Kevin in Atlanta
Kevin in Atlanta's Avatar
Default FS: 37mm spacers - Sold
Cleaning out parts bins and have had these forever.
$125 shipped CONUS
Old 05-25-2020, 09:32 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,507 Likes on 1,412 Posts
these will fit an early car and kick out the stock wheels/ tires to the fenders
Measure first both sides , use the lowest measurement from the tire sidewall to the inner lip of the fender,
NOTE this has to be 5 MM more than the spacers to fit,
EG spacer 35mm plus 5 mm = 40
So min measurement from tire wall to to fender lip must be 40mm on the closest side.
NOTE its possible with gloved hands to pull the lower edges of the fenders out a few MM to give you a bit more room
Old 05-25-2020, 10:59 PM
Wisconsin Joe
Wisconsin Joe's Avatar
EG spacer 35mm plus 5 mm = 40 min measurement must be 45mm on the closest side.
I'm a bit confused.
35mm spacer plus 5mm would be 40mm from the side of the tire to the inside of the fender.
Where does the '45' come from?
Old 05-25-2020, 11:06 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Joe I am sorry,
I put 45MM in my example instead of 40 MM.
Sorry for the confusion.
I corrected my post thanks for the proofreading
Old 05-26-2020, 10:14 AM
Wisconsin Joe
Thanks Stan.
That's what I thought you meant.
Old 05-26-2020, 10:21 AM
Kevin in Atlanta
Early car with spacers.
AirtekHVAC (05-26-2020)
Old 05-26-2020, 12:31 PM
AirtekHVAC
AirtekHVAC's Avatar
^^^now that....is one fine looking machine!....lol
Old 05-26-2020, 12:57 PM
Kevin in Atlanta
Yeah, though you might be somewhat prejudiced seeing that it is your vehicle.
Old 05-26-2020, 02:16 PM
AirtekHVAC
AirtekHVAC's Avatar
Lol...wish I took a before pic....probably have one somewhere
Old 05-26-2020, 02:21 PM
AirtekHVAC
AirtekHVAC's Avatar
I think mine are 32mm...I could have probably squeezed in 37s. Mine are el cheapos, hub centric on car side, but not wheel side, not recommended for track or high speeds....yours are nice...GLWS
Old 05-26-2020, 07:19 PM
V2Rocket
Rainman
V2Rocket's Avatar
I am interested - are these from Porsche, or aftermarket?
Old 05-26-2020, 07:59 PM
Kevin in Atlanta
How wold I be able to tell?
Old 05-26-2020, 10:25 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
look carefully for a MFG stamp
Old 05-27-2020, 07:40 AM
linderpat
linderpat's Avatar
Received 2,385 Likes on 1,294 Posts
I may be interested too. My 85 has stock spacers on the rears, which measure 10 mm. The car has the standard flat dish wheels. I tried putting my cup 3's on the rears (extra set from my Carrera). They are 18's, 10" wide, with 58 mm offsets. The tires are Mich SS, size 265/40. Without spacers they rub the inside liner. With the spacers, they stick too far out, and hit the fender lip. I am not going to roll the fenders for this (and don't want to), so I figured spacers around 5 mm will work. These spacers may be a little too thin, but maybe not. Stan, you have the same wheels, what do you think?
Old 05-27-2020, 07:54 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Ed Im confused on what your up to
Quick Reply: FS: 37mm spacers
