Supercharger install, supplemental report
#46
Thats what it looked like. I am trying to visualize what woul dbe the best process so that the whole assembly is easy to get to.
#47
Also, I imagine that spark plugs need to be changed more often with this power level and boost, so how hard is it to get the intercooler off?
#48
#49
Range Master
Pepsie Lite
Pepsie Lite
Lag is correct, if it took you five minutes to get off, you are doggin' it...........
#52
Great guys Thanks.
#53
Originally posted by prisby
Curious as to the status of the SC upgrade for an 83 shark may be
Really getting very envious of all this good stuff going on for the 32v versions
Phil
Phil
www.murf928.com
Looks like those guys have been busy up there.
#54
Administrator - "Tyson"
Originally posted by SteveM928
From the looks of things, you might not have to wait too long:
www.murf928.com
www.murf928.com
I can guarantee he's at least 2nd in line!
#56
Phil
Phil
The setup for the L-Jet cars is going extremely well. It will be as nice (or even nicer) as the 32 valve cars. The intercooler design fits so well that I have decided I will not even offer a non-intercooled version of this kit. If my real job wouldn't keep getting in the way I would have this car running this weekend already. As a matter of fact, it is going so well I am in the market to buy one of these cars for myself. I can't wait to see how a little forced induction wakes up this 2 valve car. Soon as it is up and running, with all systems confirmed, we will be taking it straight to the dyno. I'm hoping to add at least 130 rwhp with the base kit. I estimate the cost of these kits to be about $800 less than the 32 valve kit but we will see on that when all is done. I should have some pictures by next weekend.
#57
Originally posted by John..
The only thing I don't like about cranking the fuel pressure up too high is the injector can lock open. I think mine cap out at 65-70 psig on boost and they run 50 or so psig at atmospheric and about 40 at idle under vacuum. As I have heard these injectors should not be pushed much past 80 psig or you can start to have issues.
The devil is in the detials...if you can find a way to gain control of the entire fuel curve you are much better off than just having control over the limits of operation, i.e. idle and WOT.
We thought we would have to go through huge gyrations to get the fuel curve right but after messing with it a little we were able to come up with a recipe that works spot on with perfect fuel ratio at idle, cruising, and WOT. We still need to deal with the timing (at least we think we do) but we have that in the works. None of this is even close to an issue running my 8psi kit.
#58
I can't speak about the function of this boost referenced regulator, however I have it and a RR FPR in aluminum from one of our favorites:
http://www.bellengineering.net/fmu2020.html. The build quality is fantastic. No doubt in my mind that it will work. Bought it "buy now" on Ebay for less than this other.
#59
#60
This is most interesting and I am anxiously awaiting a kit for my shark
Seems like the best way to turn this older lower powered car into something that can keep up with todays performance
I will be watching this list and Tims site for updates
Hopefully I can place my order soon
Phil
Phil
