928 Forum 1978-1995
Sponsored by: 928 Specialists
New mirror
Old Mar 9, 2020 | 10:31 AM
drscottsmith's Avatar
drscottsmith
Default New mirror
Finally got my replacement rear view mirror installed today. Got a wider model from a Nissan Xterra with the compass (in orange) and the automatic dimming. Wanted one with temperature display but could not find one at LKQ.
Replaced the button as the Nissan model has a different one. Only two wires to connect...for power. Ran them down the A-pillar to the CEP and connected to fuse 10 (unused in 1983) which I fused and is connected to the 15 bus, so the mirror turns on with the accessory circuit.
Nice wide mirror compared to the old one and updates the interior a bit without being harsh.
Old Mar 9, 2020 | 11:00 AM
j.kenzie@sbcglobal.net's Avatar
Looks very nice. When I did something similar, I had interference with my sun visors. Hopefully you had better success.
Good luck,
Dave
Old Mar 10, 2020 | 07:58 AM
Petza914's Avatar
Petza914
Nice job Scott. I did a Gentex one with Homelink buttons and auto dimming. Looks similar to the ones in the newer Camaro which goes with the rest of the silver trim in my interior and works with the sun visors.
Old Mar 22, 2020 | 05:11 PM
whiteNSXs's Avatar
whiteNSXs
Great mod. Do you have to remove the entire old mirror and button or there is an adapter to fit on the old button?
Steve
Old Mar 22, 2020 | 06:08 PM
drscottsmith
Hey Steve -
I had to replace the button as well. Comepletely different style on the Nissan (Gentex) mirror.
in the pick and pull, the mirror and button came off of the xterra pretty easily. Getting the old button off of the 928 was a challenge. I ended up using the string method to get the button off (cut through the adhesive then scraping the remaining adhesive off.
very concerned about breaking the 38 year old windshield glass.
be careful!
also, you will want to go by a glass repair shop like safe lite to get them to glue the new button in place. The stuff you get at the auto parts store is crap.
-scott
Old Mar 22, 2020 | 07:56 PM
Alan's Avatar
Alan
Electron Wrangler
The old button will come off quickly and easily with a propane torch - yes I know it sounds scary - but it really works best. You can shield all but the button with foil if you like - but it only takes a few seconds (~3) heating directly onto the button to heat the adhesive enough to just twist it off with pliers - then clean up residue with razor blade. The windshield hardly gets warm to the touch.
Alan
Old Mar 23, 2020 | 12:16 AM
whiteNSXs's Avatar
whiteNSXs
Thanks, guys. I think I will just take off the mirror but leave the original button on the glass. I will glue the new button next to the old button or above it. How does one take out the original mirror?
Steve
Old Mar 23, 2020 | 12:59 AM
Bmw635's Avatar
Bmw635
Great upgrade. I'll look for one that has Homelink built in.
Old Mar 23, 2020 | 01:06 AM
mkhargrove's Avatar
mkhargrove
that's definitely going to be on my list of things to do. thanks for the info!
Old Mar 23, 2020 | 10:50 AM
Jerry Feather's Avatar
Jerry Feather
I have developed a plan to replace many of mine with a Boxster mirror. I cholse that mirror because it is stil Porsche, but mostly because its shape, kind of an upside down trapazoid, is much closer to the shape of the image in the original mirror thru the rear window of the 928. The button must be changed since the original mirror removes upward and the new mirror twists 90 degrees to install or remove, either way I think. You can find these mirrors on eBay at around $35 to $50, but if you buy one there you want to be sure that it comes with the original button, because many of them do not. When you get it with the button the button will likely be installed in the mirror and then it is a trick to remove it. I have forced a couple of them out, but I think next I will simply clean the broken glass and adhesive off of it still in the mirror base, then glue it to a short piece of alumminum flat bar and when it sets simply twist it off/out.
As to installation, I would first put a grease pensil mark on the outside of the WS where the original button is so after it is removed and cleaned up there is no question about where the new one goes. If the mounting shaft of the mirrors are different you can adjust for that to keep the mirror itself in the right location. Alan's suggestion about using the torch to remove the button is very encouraging, but I think I will fashion a sheet of aluminum to keep any flame off of the glass. Then, as suggested, take the car to the window shop and have them glue the new button on for you. I would wait 24 hours or overnight before twisting the new mirror onto it.
