928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel rail connector sizing specification
Old Feb 20, 2020 | 01:25 PM
FredR's Avatar
FredR
Default Fuel rail connector sizing specification
The connections between the fuel rail and the pressure regulator/dampers obviously have a sizing specification- anyone happen to know what size/system they are?
Old Feb 20, 2020 | 01:33 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
I believe they're M16x1.5, torque is 22 ft lbs. The tech spec book calls them 'union nuts to fuel distributing pipe'.
Old Feb 20, 2020 | 01:38 PM
FredR's Avatar
FredR
That was quick!
Doubtless a good starting point- presumably the spec will have a name or convention- I would expect such to be a metric version. Gives me something to do further search with- I drew a blank from a general search on google.
Old Feb 21, 2020 | 01:43 PM
FredR's Avatar
FredR
The only spec I have been able to dig out that looks sort of compliant is ISO 8434-2 which shows the sealing face using a 37 degree plain compression face. My instincts tell me this is more like the spec that is used in the AN connectors. I believe the Germans use ISO specs regularly but could well be wrong on this one.
Any thoughts?
Old Feb 21, 2020 | 01:45 PM
Rob Edwards
Archive Gatekeeper
I spent a few minutes googling around for a DIN standard describing metric fuel fittings but did not find anything. Will keep looking.
