928 Forum 1978-1995
Sponsored by: 928 Specialists
Are the 85-86 pistons "quiet" enough to use knock sensors?
Old 02-18-2020 | 07:05 PM
  #31
The Forgotten On's Avatar
The Forgotten On
They're all group 1 pistons so getting a few extra wont be too hard. Or I could have the valve reliefs mirrored on all 8 pistons and drop the CR a bit so it's happier on pump gas.
It seems like there is enough room on the piston head and it would help when boosting the engine at some point.
I don't think the edges would cause hot spots and pre-ignition issues, but I could be wrong.
Old 02-19-2020 | 11:16 PM
  #32
GregBBRD's Avatar
GregBBRD
Former Vendor
Originally Posted by The Forgotten On
They're all group 1 pistons so getting a few extra wont be too hard. Or I could have the valve reliefs mirrored on all 8 pistons and drop the CR a bit so it's happier on pump gas.This might work. Calculate the compression ratio and see where you are at.
When in doubt, just hand sand the edges of any of the sharp cuts for the valve reliefs and eliminate the sharpness of those edges.
The Forgotten On (02-20-2020)
Old 02-20-2020 | 12:11 AM
  #33
The Forgotten On
I'll try, just need to get a kit to CC the combustion chambers and pistons and go from there.
If it is around 9.5:1 or so (after figuring in an extra set of valve reliefs) I will be happy. I intend to run it on pump gas, 87 if possible like the 81 originally used. I like a fast flame front
Quick Reply: Are the 85-86 pistons "quiet" enough to use knock sensors?
