16” ET 23 phone dials come 7” and 8” wide.
Will the 8” fit on the rear without rolling the fenders, or would I need to stay with the 7”?
Either with 225 50 or 245 45?
I beg to differ Stan. This is an ET 23 with a 225. It won’t rub but a 245 will unless you roll the inner lip. You won’t have to roll the panel itself out.
Is the picture a 7” or an 8”?
I know what they came on, and I know they look slightly different because of the offset and outer edge, but the difference is minimal.
I know what the stock offset is and plan on staying with that on the front.
A wider rear track without spacers is what i’m looking for.
I haven’t decided if I want to roll the rear fender edges.
They are 8”. The outer offset edge is what I like most about them. The fronts are the 928 ET65 and I think they look great together.
I apologize as I was supposed to get back with you on a price for a pair. I have a couple if are still in need. Let me know and I will shoot you a price.
-A 245 tire is not a 245 tire. They are different size depending on brand / Type / square shoulders etc.
-Is the car standard height? Is it higher than std spec.? Lower?
I added very little camber (Still within specs) on a lowered car 86' with a Toyo 245 rear tire. No issues.
