Is it a plastic or leather dash? I'd try a mild leather conditioner spray or a general interior cleaner. You can get Chemical Guys products at Walmart (I'm a huge fan of their Total Car Interior Cleaner and Protectant). If the dash seems dried out, I'd try a leather conditioner (Lexol) and then follow up with an interior cleaner to remove any glossiness the conditioner leaves.
I don’t think it is overspray. They taped up the windows when they took the glass out. It was just a very chalky dust and cleaned up easily. Because the color changes to what it should be when wet, I’m thinking some sort of conditioner that won’t affect the UV protection of the dash.
It’s overspray that misted beyond the plastic sheeting. As mentioned, a properly used clay bar should remove it, but it may be a pain on a surface that isn’t smooth.
Over-spray is very sneaky. It can get anywhere air goes
Try this sterling.
works great on plastic, leather, anything interior.
if you wanna to hook up over the break, I’ll give you the bottle I have so you can try it out.
Low sheen, good leather scent..
