928 Forum 1978-1995
Sponsored by: 928 Specialists
Door stop, installation hints
Old Dec 22, 2019 | 12:44 PM
vsalvato's Avatar
vsalvato
Default Door stop, installation hints
I would like to install new door stops on my S4/MY88; I have no clue how complex the job is and if doable by a non-professional. IS there any video/picture which could help me with this task? I read that new stops are usually more "aggressive" than old ones, meaning more effective in self-closing the door but also more noisy... I also read that moly grease lubrication helps minimizing the problems and smoothing the mechanism. Thanks in advance...
Old Dec 23, 2019 | 11:15 PM
Wisconsin Joe's Avatar
Wisconsin Joe
Try this:
https://rennlist.com/forums/928-foru...-033-04-a.html
Old Dec 23, 2019 | 11:30 PM
Speedtoys's Avatar
Speedtoys
With the door card off, you can get er done with some patience and worst case a magnet to help IIRC...and patient fingers. The door card is the "hard" part, and it isnt that hard.
Feels good to have new ones installed, too.
Old Dec 24, 2019 | 03:52 AM
vsalvato's Avatar
vsalvato
In the thread to the link someone mentioned a different fixing method for the door stop problem using Jageng door stay kits. The link does not seem to work anymore, anyone can check and confirm what this wonder kit consists of and if it is still available to see and eventually buy?
Old Dec 24, 2019 | 04:12 AM
Speedtoys's Avatar
Speedtoys
6.5.0
They're shims to grab the rollers in the OEM assembly better that sandwich onto the arm that goes into the door,
FWIW, just buy new parts...fix it properly.
Old Dec 24, 2019 | 08:15 AM
murray928's Avatar
murray928
https://garage9.com/collections/nuts...r-arrestor-kit
This is the new link to the door arrester kits I bought from Jager / Garage9
First class fix.
Old Dec 24, 2019 | 08:27 AM
murray928's Avatar
murray928
First class fix.
Old Dec 24, 2019 | 08:30 AM
slownrusty's Avatar
slownrusty
Originally Posted by Speedtoys
6.5.0
Agreed! No need to put a fix on a warn part, just address the warn part.
Old Dec 24, 2019 | 10:41 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I have been using the DC 111 on the door check and the rollers this to keep water from rusting the metal rollers once they rust the door check will rapidly wear out
the water runs off the front edge of the window seal and drips onto the door check
Old Jan 1, 2020 | 06:53 AM
vsalvato's Avatar
vsalvato
First class fix.
MAny thanks for the good hint! Happy NY and New Decade!!! By chance do you know if the repair kit comes with detailed instructions? Otherwise anyone able to tell me before I order the parts?
