Good morning all.
getting ready to start cleaning two engines worth of parts. My machinist has a tank that has Mirachem in it. It is amazing. But crazy expensive.
Looking for suggestions for best solvent to use to soak parts in. Currently I’m thinking brake cleaner.
I just ordered POR15 Degreaser (Amazon), but haven't received it yet, so I can't rate it. Perhaps you can put it on your list of materials to take a look at.
Believe it or not I have Pine Sol in my tank. I think I mixed 1 to 1 with water if I remember correctly. I have a small tank and it works very well, less toxic etc.
I use Anchor Atlantic US2003 in my ultrasonic parts washer. Aluminum safe and works wonderfully. I was turned onto this by Jake Raby of 911 motor fame when I took his M97 engine assembly course a couple years ago.
Thanks all,
I was leaning to brake clean initially.
This is not for a parts washer. I have something a bit different in there.
This will be for a 20 gallon oil drum soak tank.
I could not find the Anchor Atlantic US2003, during a quick search.
Tractor supply has Crown PSC 1000. 5 gallons @ $50.00.
