Oil Change Reset?
I just changed the oil in my 89 S4 and I'm getting the "dash reminder" to check the oil level. Is there a way to reset this? I did a search on the forum and didn't find an answer.
It is only a single wire that connects to that level sensor. Make sure that the wire is connected and not laying on the top front of the oil pan.
If it is the sensor, yours and one other would be the only two I ever heard of that were bad, so it's not impossible for it to be bad.
Received 1,638 Likes
Possibly it was disturbed during R&R of the oil filter. If so, then the harness branch to the level sender was mis-routed.
