Manual transmission mounts not lining up on cross member.
Hello all,
I have a 1980 928 that I've been doing a manual swap from an automatic on. Everything has gone well, bolted up nicely, except with the rear crossmember bolted to the body, and the torque tube bolted together, the transmission motor mounts are about an inch further back than they should be. Any guesses on to what could be causing this? Everything else has lined up very well, It's just like the torque tube is an inch too long or something.
All the donor parts were out of a 1979 manual.
Thanks!
Wesley
Thanks!
Wesley
the auto has a different cross member than the manual.
Team Owner
call 928 intl and buy a used rear 5 speed crossmember
Team Owner
.I have a 5 speed cross member as well- from the same car.
what does this mean?
Archive Gatekeeper
What is the part number of the rear crossmember that was originally on your 1980 Automatic, and what is the part number of the rear crossmember from the '79 that you've installed?
How long (in cm or mm) is the torque tube from the '79?
What is the transmission model number and serial number printed on the bottom rear of the case?
Team Owner
because there are different rear cross members
I did the same swap a couple years ago. 79 manual trans to 83 auto trans. Everthing from the 79, from flywheel back to cross member has to be used. I swapped all the the 83 suspension parts onto the 79 manual crossmember, before installing the entire assembly at one time. The manual trans does not fit the automatic crossmember.
Sorry for the confusion, I pulled everything from bellhousing/flywheel back off the ‘79 donor car. Including rear crossmember.
I will provide serials when I get back to the house, but the parts from the 79 donor car are flywheel, clutch, bellhousing, torque tube, transmission, and rear crossmember.
So- here's a breakdown of part numbers and lengths for parts:
Auto parts that got removed from the '80 automatic:
Transmission Serial: A22 922 321 101 3R
Rear Crossmember: 302810 0 80701
Parts that got removed from the '79 Manual donor car:
Transmission: G28/03 1190619
Crossmember: 928.331.131.14
Torque tube is approximately 144.75 cm, flange to flange, +- 5mm.
Archive Gatekeeper
So the 144.7 cm torque tube is correct in a '79, and worked with a G28.03 transmission. That '79 TT is 30 mm longer than the '80-95 torque tube, because the G28.03 transmission sat 30 further back than the new-in-mid-1980 G28.05. transmission. (They moved the mounting of the G28.05 forward 30 mm to decrease the angle of the axles). PET says that the .14 rear crossmember is used only with the G28.05 transmission. So I'm a little confused how the .14 could have worked with the G28.03 in the '79 donor. You need a 928 331 131 13 rear crossmember, which superceded to a 928 311 131 17, either would work with the '79 trans.
Early vs. late torque tube dimensions:
![](https://webfiles.uci.edu/redwards/public/Torque%20tube%20dimensions%20and%20bearing%20support%20spacing%20Pal%20W%2010-13-18.jpg)
Bill Ball (12-01-2019)
