Need Help Identifing the 12 VC Gkt Set part numbers
7th Gear
Hi you guys and gals . What a day. Hope everyone is having a Good Day. I need a little help identifying the missing VC Gasket Set part name and numbers ? Your assistance is Greatly Appreciated.
ref; pic
Wrightwood Racing 9281044470998 60 pieces
I have 42 pieces I bought for my 88 928 S4 I'm missing !8 pieces according to the pic
6 x 928 105 215 00 Camshaft End Seal
8 x 928 104 443 08 Spark Plug Seal
26 x 928 104 115 02 Valve Cover Bolt Thrust Ring, Rubber
2 x 928 104 447 09 Cam/Valve Cover Gasket
2 x ?
4 x ?
12 x ?
Louis aka DirtboyNay
Team Owner
the 2 at the top not circled are the rear coolant gaskets for the Heater Control Valve port and the block off plate at the rear of the heads.
the 4 if the they are rubber O rings are for the 2 vent ports in each cam cover, the driver side has plugs in place of the vents on the right cover.
The 12 if they are silver sealing washers go under the the 6 lower bolts on each cover to increase the clamping force you should get more of these to do every bolt so the gasket will get more clamping
