Removing the fan clutch
As I am replacing the bearings on the fan support, I want to get the clutch off the shaft. The bolts are on very bery tight.
Does anyone know if the are rh thread or lh thread?
cheer
cheer
Team Owner
Righty tighty
lefty loosey
lefty loosey
??? The nut at the back (engine end) of the shaft comes off, the pulley comes off a woodruff key, the key comes out, the shaft slides out to the front. The actual viscous clutch doesnt come off the shaft, except in pieces, with the aid of a BFH, in my experience. One or both of the bearings may be retained by a circlip. Both common cheap bearings.
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
