I just noticed this....84, front driver's side.
The inner side appears to have no damage...the outside is split where the bolt threads in, and the bolt is bent. The bracket is a bit bent as well.
Is this something that I need to fix asap? I do have a vibration that's at it's worst at 72 mph. I doubt that this could be contributing to that, but maybe someone knows better?
Also, do I need to replace the entire control arm, or does the end come off????
Call Richard Maddox. If he is coming to the breakfast, he might be able to bring you a used one.
