Maybe you can find your current rims on that site as well. I personally - even though I love originality in cars - would not go back to 16" wheels. Rather I would upgrade my power steering pump and rack to the '91 and later setup with higher power assist. That combined with the 17" wheels is a huge imiprovement over any 928 with 16" wheels I have ever driven.
The machining on spokes are almost identical to my Forgeline Wheels and the machining marks also look like it is machined from a forged metal, so I would stick my neck out to say that you got a set of forged wheels that were made in 1995 with a 620 kg maxium load rating. I would think you would get $800 to $1000 for them if they are true and straight, and no leaks.
Thanks. I thought the valleys on the back of the spokes (where the spokes are not machined, for example around the word "Japan") and the words themselves looked cast.
The E-bay wheels are design 90 CAST wheels .....no magic there . BUT were what was fitted to 90> GT cars . They were far less expensive wheels . If you can find 4 of the forged rears 9x16 you can run two of them on the front with 245 width tires !!
My Forgeline wheels look the same at the valleys on the spokes. I was concerned also about the raised lettering on the spokes (usually that means cast) but I think in this case they were just rough forging.
