Odometer problem - burned resistor on circuit board
I've got a broken odometer on my 1986 Euro S. I replaced the odometer gear some years ago, and after that the odo worked fine. Now it died again. I guessed that iy was a gear issue again, and took it apart. No broken gear, and it counts fine when rotating the mecanism. There must be a electrical issue in the odometer. The speedometer works, so the impulse sender on the differential, the flexible circuit board, wireing etc must be OK. The problem must be in the odometer instrument. I found this excelent thread about problems i the instrument. It´s only one problem with it. The pictures are missing.
I soldered the step motor out of the board, and checked it according to the instructions. It works perfectly. I found one burned resistor on the circuit board. In #17-18 in the thread they talk about checking a resistor, that should be 22 ohms. Which one on the board is that? Anyone got the pics from that thread?
Anyone know the value on my burned resistor? I soldered it out of the board, and it is about 48 ohms now. I don´t know if it is the correct value, but it neeeds to be replaced. Maybe some other components too? It is the UAF2115 chip.
I have the same burned resistor on my 85. I have no speedometer or odometer at the moment. It would be nice if someone sold just this circuit board, vs having to buy a complete speedometer assembly
