928 Forum 1978-1995
Sponsored by: 928 Specialists
Spark Plug Heat Range Cross-reference
Old Jul 2, 2019 | 03:35 PM
Petza914's Avatar
Petza914
Default Spark Plug Heat Range Cross-reference
Can anyone confirm if this spark plug heat range cross-reference chart I found seems accurate or not.
In my supercharged '79 I had been running NGK BR8ES plugs in my car and recently switched to Bosch. I thought the heat range for a Bosch plug in a standard 928 was a 7. Being supercharged, I went 1 range colder to a 6. Bosch #s get colder with the lower numbers whereas NGK plugs get colder as the number increases. With a Bosch 7 I though I was comparable to the previous NGK 8,but according to this chart, I'd need to be in a Bosch 4.
I don't think I've ever run this cold a plug in any of my cars.
If others (Eric, Dave, Carl, etc) have recommendations for my setup, I'm open to those as well
Thanks.
Old Jul 5, 2019 | 08:31 AM
Petza914's Avatar
Petza914
Since no one has responded yet, let me ask the question a different way.
What are the recommended NGK and Bosch plugs for a 16v 928 engine and what's the plug gap?
Anyone running a supercharger, and what plug and gap are you using with your setup?
Thanks.
Old Jul 5, 2019 | 09:04 AM
SeanR's Avatar
SeanR
I use a Bosch 5 and gap them at 30.
Old Jul 5, 2019 | 09:13 AM
Petza914's Avatar
Petza914
Thanks Sean and your car is supercharged too, correct?
Old Jul 5, 2019 | 09:47 AM
SeanR's Avatar
SeanR
Yup.
