Need GTS Parts - Intake tubes and Upper Air Box
Looking for the last of the parts I need to complete the de-superchargification of the Black GTS.
Hoping someone actually has these.
PM me.
Best regards, Kevin
PM me.
Best regards, Kevin
Sorry to jump in but I was just going to post the same thing. Does anyone sell replacement Insulated air intake tubes?
Originally Posted by bfellows
Pair off intake tubes boxed, brand new, on ebay at the moment (sorry no link, bit of a rush post)
928 intake tubes on ebay
I don't think you can get "new" factory originals any longer. There was a aftermarket intake tube available but it is not an exact copy of the factory original. Good luck.
DR found the ones on my GTS. I'd start there. I am always on the prowl for the insulated tubes. Last year I snagged one of Ebay for $100. After all, it's not if the insulated tubes will self destruct, it's when.
Thanks,
I will be ordering all sorts of goodies in the next few months. The insulation is cracking on the intake tubes and I was thinking of buying a set and saving them for shows and such. I guess I will see whats available.
There has got to be a way to re-apply the rubberized coating on the tubes to make them look factory fresh? Wonder if the rubberized spray Home Depot sells to coat the handles of tools would work?
I don't think so. That stuff is pretty thick and not as flexabale. It does a great job for tools but I doubt it would work on this. Guess its time for a google search and see if there are companies that recoat this type of stuff.
Does the insulated intakes keep the air temp down that much? The primary intake scoops are still above the hot radiator. I would think positioning the intake scoops further forward or down into the air stream would have done more. Or was this done just to keep the plastic from becomeing brittle from the engine heat?
I checked last week for new tubes for my 88...the old style tubes were $38 each and the GTS tubes were $157 at Devek! Ouch....but thats why GTS's are worth so much I guess?
Does the insulated intakes keep the air temp down that much? Or was this done just to keep the plastic from becomeing brittle from the engine heat?
The GTS insulated tubes were for NOISE reduction " all GTS vehicles are fitted with noise reducing intake hoses of the same type used previously on export models for Switzerland." quoted from service technik 1992. The tubes are available but do cost about $150 and unfortunately Porsche puts paper part number stickers ON THE FOAM parts and trying to remove them tears the foam !! Switzerland apparently has more restrictive regulations about noise emitted by autos I had heard that was one reason Porsche opted to watercool the 911s to meet drive by noise requirements in some European countries.
I am assuming you are talking about $150 ea. Is this something that you stock or does it need to be ordered and will take the standard 6-8 months for Porsche to ship and pricing dependent on euro conversion of the time?
