333.6rwhp!
#32
Originally posted by tomboyea123
That is soooo clean.Where did you get the intercooler? I am sure that is a real key to the package.
I'm not sure where Tim gets the intercoolers made to his specs, but I think they have SpearCo(?) cores. But that's the easy part as anyone can build an intercooler.
The REAL 'key' to the package though is the bracket and tensioner, along with the 8-rib pulley setup.
The bracket has three planes of support so that there is absolutely NO flexing/deflection whatsoever under boost. I've put over 5000 miles on the setup, and the belt still looks brand new without any 'belt-dust' anywhere. Once properly tensioned, the belt stays tight and does not slip. It is a piece that has to be seen to be appreciated. The bracket does not resemble in the least the original one Tim started his supercharger journey with, although that one works just fine for lower boost applications.
