928 Forum 1978-1995
Sponsored by: 928 Specialists
PLASTIC DASH CAP ADHESIVE
Old Mar 18, 2019 | 02:25 PM
PC-85-928S's Avatar
PC-85-928S
Default PLASTIC DASH CAP ADHESIVE
From all the posts I have read, the general consensus on plastic dash caps is, Don't Do it!
They will warp and look bad-
My question is if you had to do a plastic dash cap due to budget restrictions, what adhesive/glue/silicone would you use?
The dash would be out of the car.
Also how would you prep the dash prior to installation?
(yes I know they suck-ty)
Old Mar 18, 2019 | 02:39 PM
danglerb's Avatar
danglerb
If you have dash issues it means the dash was exposed to hot sunny conditions, those same conditions will shrink the cap in short order the type of adhesive won't mater much except for the later removal of the mess. Budget solution is carpet.
Old Mar 18, 2019 | 03:18 PM
NoVector's Avatar
NoVector
On my '84 I used the silicone stuff that came with the dash cap. It smelled like aquarium cement. I had no issues with it warping BUT this is what you have in store when you remove it. The horror... The horror.
Old Mar 18, 2019 | 03:22 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
+1
If your dash / pod are in decent shape except for a crack or two, it will be destroyed after removing the cap with adhesive.
Here's the aftermath of my dash / pod. From what I could tell it seems the cap was used to cover up some very small cracks, which I would gladly live with compared to this:
https://rennlist.com/forums/928-foru...-overlays.html
Old Mar 18, 2019 | 04:04 PM
checkmate1996's Avatar
checkmate1996
Yep - that's what happened with mine too -- pretty much toast...
