View Poll Results: For only a head gasket replacement only on a 16v and no other service work, would you
Voters: 59. You may not vote on this poll
Blown/Damaged Head Gasket?
#91
Hi Pete,
I have the Porkensioner also. It works just fine, and it's also possible to remove or release tension on it from below, with the supercharger in place. I needed to do that when I corrected a one-tooth error on my timing belt install.
Good luck,
Dave
Good luck,
Dave
#93
#95
Got one of those, actually two and while they have worked for me in the past, I'm not a fan. The one I'm working on right now Cheap-o-that works at the house came with the engine I just completed and it's much, much sturdier than the one you posted and I've been using. Hated how my old ones wiggled around on the set pins. Guess I"m getting old, I want sturdy one with a crank so I don't have to muscle it around.
Just out of curiosity, how can yours rated at 1,000 lbs be sturdier than mine rated at 2,000 lbs?
#96
Team Owner
Pete You can get that adapter for the X pipe from Motorsport in Utah
#97
Thanks Stan. Mark Anderson pointed me in that direction last week and Dave is making me one. Should ship early next week.
The headers arrived yesterday too (thanks Jim).
Motor and related parts have been shipped too. I need to order some things from Mark and Roger, but in about a week, I'll be the hold-up and should have 90% of what I need on hand.
#98
Read my post a little closer and you will have a better chance at understanding what I said.
#99
Again, I have both, and their listed specs accurately reflect my experience with them. I had to put a jack under the engine's nose to help support the then-brand-new 1,000 lb capacity stand. For the 2,000 lb capacity stand, no additional support has ever been necessary. Because of this, I've never used the 1,000 lb stand again.
So, basing/making a recommendation using a worn-out piece of equipment as an example, is not exactly good advice.
The numbers do not lie for in-spec, brand-new engine stands - 2,000 lb capacity versus 1,000 capacity, and their numbers accurately reflect my experience with both of them.
#101
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/20190401_074841_8d00ce3f28ae58f77afd5cdb1135dca44d1cd712.jpg)
Probably elementary questions, but how and where do I connect the lift chains to the motor once I'm ready to pull it and also how and with what bolts and where should it be attached to the standoffs on the engine stand.
Also, is there a good link to a complete write-up on waterpump replacement and cam timing setup? Though I'm not changing the waterpump, I'll need to do the rest of it for reassembly.on the 4.7L motor.
With JP's soccer games both days, I didn't get much done over the weekend, but hoping to make some progress during a couple evenings this week.
Thanks.
#102
There should be lifting eyelets near cylinders 1 and 8 but being at opposing corners it is awkward even with a load leveler. I will try this method next time: https://rennlist.com/forums/928-foru...ft-points.html
I used this excellent water pump/timing belt guide: http://static.ibsrv.net/autocomm/Con...ber%202011.pdf
#103
Use this one and you will have no issues.
#104
Interesting idea from Kevin on the lifting points too - might need to get some steel angle iron and a couple large eye bolts at Lowe's today.
#105
they worked great with the load leveler.
Pete, you want to borrow them?
