Mercury Racing LS7 Crate Motor
Coyote Aluminator swap in an '89 has been done already.
http://forums.linkecu.com/topic/7682...8-coyote-swap/
I don't understand installing an engine into a car when you don't have an functioning engine management system to make it work.
Using the GM LS7 block, Mercury designed a set of aluminum DOHC (dual overhead cam) cylinder heads, providing four valves per cylinder. By ditching the pushrods and adding two valves to each cylinder, the engineers at Mercury were able to move more air, faster through the LS7 block, resulting in an increase of 245hp over the LS7’s advertised 505hp.
Vegas, Baby!
I know nothing about it other than what I read on the web site:
Why anyone would stuff a Chevy engine, or complete drive train in a Porsche is beyond me. Just buy a Vette, and be done with it.
There are a few here that know my Pantera, had a blown 572 big block Chevy in it for over 20 years.. I wasn't the first to put Chevy power in a Pantera, and one guy has 426 Hemi,in one over in Europe. The Cleveland engine was a turd when it was built, and I've never owned a Ford engine that didn't use oil. They got bad valve seals. Now it's got a modular supercharged Coyote in it, we'll see how it does. 1100 hp from the factory, with a warranty, ain't bad.
And, seriously, electronics are the biggest reason I'm planning on doing an LS swap: These Bosch EFI systems were cutting edge at the time, and they're 40 years old now. Capacitors are drying out, solders are going bad, traces are getting tired. How many times have non-start problems been solved by swapping out an EFI module? How much does it cost to rebuild an EFI module?
And I know that working on a 928 motor isn't rocket surgery, I've done some. But compared to a Chevy? Yeesh.
Engine management has to be installed, but I have yet to find an article where that was a huge deal with an engine swap. Normally the biggest problem is fitment and mating to the bell housing. Those have been solved for the 928 and the LS motor.
The V8 in the Cayenne is too tall to fit under the hood of the 928.
Pretty sure that the Panamera V8 is derived from the Cayenne (could be wrong on that and welcome correction if so).
Why reinvent the wheel? Buy the engine along with its factory tuned ECU.
Received 1,604 Likes
Should at least be sufficient...
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
If they make a set of 4-valve heads for the LS engines, count me in. The 5.3 in my garage will not be going in a tracked 944; it will be going into my 928 and megasquirted. Screw California; I barely drive the car and will apply for historic plates.
When it comes to crate motors, Jegs has a nice LT1 for sale that earns "E-ROD" in CA. That means it's smog friendly and 455HP. What's not to like?! It costs the same as a full engine rebuild!
Vegas, Baby!
It's still a 44 year old car, though everything has been upgraded. I don't really push it's limits, it's a hoot to nail it out on the open road, and it just keeps accelerating! All the ground effects were wind tunnel tested at JPL , back 25 + years ago. It hunkers down on the road, never gets light in the front. It's no GT by any stretch. It's a very fun car, gets lots of looks!
