928 Forum 1978-1995
Sponsored by: 928 Specialists
Tested my old plug wires...found it.
Old 01-20-2019, 08:17 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Default Tested my old plug wires...found it.
Ive had a grumbly rough running from a dead stop for a few seconds, and under load esp at highway speeds.
Here are the per wire ohm readings:
1 1798
2 1797
3 1775
4 1781
5 1796
6 1790
7 - Tested as a separate wire end plug end, the end was 885, and the wire was 1564. Lots of green and corrosion in the end where the crimped wire end remained.
8 1779
coilR 881
coilL 882
Went to unscrew the ends to take a peek, and the plug end of 7 just 'came out'.
The plugs looked normal when GB and I looked at them at Sharkfest (issue has been around a while)..and it was green and ugly. So that spark was doing extra work, and was "weak"..
And that's what over time, ate up my OEM cats, and why I had to buy new ones to get past smog.
It was doing that, that made me dig into this over the last while, to wonder why.
They were original wires best I can tell...and everything is "better" about the car, as would be expected after such a result.
Will be on the dyno again mid March, so I can track this result as Ive done all others.
Old 01-20-2019, 08:23 PM
merchauser
merchauser's Avatar
great news! new wires made my car a new animal
always good to find the culprit; more than justifies the new wire cost
Old 01-21-2019, 04:50 AM
FredR
FredR's Avatar
It would be interesting to see some resistance values of your old wires and the new ones for that matter.
Old 01-21-2019, 11:21 AM
merchauser
merchauser's Avatar
what is the best way to test values? setting on my multimeter?
Old 01-21-2019, 12:03 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,706 Likes on 1,309 Posts
ohms. 5K, 10K , or 20K, whichever your multimeter has.
Old 01-21-2019, 06:05 PM
ROG100
Basic Sponsor
ROG100's Avatar
Just wet your finger and you will know straight away which one is bad 8>)
Old 01-21-2019, 06:07 PM
Otto Mechanic
Otto Mechanic's Avatar
Or you could save the cost of a good multimeter and just buy new plug wires, because that's what you're going to do anyway.
Old 01-21-2019, 06:08 PM
Otto Mechanic
If you use your tongue there's no need to wet it. Saves a step.
Old 01-21-2019, 06:10 PM
Otto Mechanic
Or you can always conscript a dog's tongue. Use a small dog. Rottweilers should be avoided.
Old 01-21-2019, 06:15 PM
Red Flash
Red Flash's Avatar
Allow me to quote Goethe: "Du sprichst ein grosses Wort gelassen aus."
Glad you are enjoying the new found health of your engine!
Old 01-21-2019, 08:30 PM
Otto Mechanic
And that is indeed a mouthful.
Old 01-21-2019, 10:01 PM
Speedtoys
Speedtoys's Avatar
But,..one should have a good meter..anyways...
Old 01-21-2019, 10:09 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
If you own a 928 and aren't well endowed financially, a good DMM should probably live in your tool collection at home. I have one of those giveaway Harbor-Freight DMMs in the riding toolbag, JIC.
In my teenage years I worked in a small local auto parts store for a while, after school and on Saturdays. Folks would come in with ignition issues, and buy a new coil when they couldn't figure out the bad condenser. Then they'd try to return the coil as defective when it didn't solve the problem. I rigged a battery and an old distributor to demo coil functions. For insistent customers, I'd show them that the new coil is fine, and would do the same with their old coil if they brought it. For those non-believers, I'd recommend that they put the business end of the coil wire in their mouth and that they then spin the distributor themselves. Nobody would do it.
Old 01-21-2019, 10:14 PM
Otto Mechanic
Cost of doing business, as they say.
Old 01-21-2019, 10:17 PM
Otto Mechanic
Those were the folks who clearly had limited access to a willing dog.
Quick Reply: Tested my old plug wires...found it.
