What Kind of Wheel is This?
I have the ATP RIVAS and the caps fit them. I had to knock down the front bearing cover for an added few MM of clearnce.
I think they are the RAZZE?
check www.928gt.com under Performance Products..then wheels
Thanks Tony,
Saw on another thread you were looking into a new keyless entry/remote start system? I am interested to see what you end up with. I read your write up on your initial system and decided I HAD to have one. Seems a bit simpler for an auto than a manual but I haven't looked into that part.
From the site- (not compatible with front S4/GTS Calipers),
That looks and I think is my wheels but I have a GT and the site states the above? I am not a wheel guy so any help is appreciated.
ANTERA
17" or 18" Type 121
8.5 x 17" front and 10"x 17" rear - Complete Set $1750
8.5 x 18" front and 10"x 18" rear - Complete Set $2250
Maybe a set of these with ATP center caps as both wheels are compatible with factory center caps.
17" or 18" Type 121
Originally posted by Jim Hurtt
If I took a wheel "off".
I think the easiest way to tell would be to look at the tire sizes or measure the wheel widths. Anteras are 8.5" & 10" in width, the ATP Razze wheels are 7.5" and 8.5".
