WTB: Flappy valve shaft plastic colllar
This small delay will give you plenty of time to clean and re-clean the intake to make sure it's absolutely clean and free from debris.
Basic Sponsor
Ah, I see. They ride inside the spring, not the bore of the housing. What material will you use for this? I use PLA and ABS on my printer, but not sure if either of those will hold up to heat and fuel.
Cool. Can you also verify that the #2 and the #7 spacers are identical like Luis stated?
Done. As soon as I get them check fit and verified by Luis (or Rob if Luis can't) I will put you first on the list.
I can't absolutely verify that #2 and #7 are identical since I lost #2 but I can't envision how they would be different.
I won't have my intake back for maybe 2 or 3 weeks so any fitment test would have to wait until then, but I am happy to do it.
The depth I am missing in your annotated pic is 2.18mm and the inner diameter 19.30mm.
Regarding the ribbing in the back of the part, I imagine it's a way to make the part stiff while minimizing the amount of raw material utilized... The only other thing I can think of is that the small chambers can keep some oil in the rotating surfaces. To that end, I would just carve some channels with a dremel if the reproduced part ends up being flat in the back for production simplicity.
Archive Gatekeeper
Shaft OD- 9.97 mm.
