928 Forum 1978-1995
Sponsored by: 928 Specialists
Coolant Level Sender
Old Nov 4, 2018 | 05:52 PM
awilli6's Avatar
awilli6
Default Coolant Level Sender
Hey gang,
I’m getting a check coolant level alarm on my 89S4. The level is fine. I’m not loosing coolant from anywhere. Is it possible to test the sender via a multi meter? Is there anything else I need to check? I did change my “J” hose on the bottom of the expansion tank. That fixed the leak I had. I let it run for 20+ minutes without the cap so I think it should have burped. I ran it so long the coolant was approaching the top. Not enough to spill out the top but it seemed like if I kep it running, it would have overflowed.
thoughts?
Old Nov 5, 2018 | 03:08 AM
Schocki's Avatar
Schocki
Theses sensors fail after many years. Happened to my GTS too, just get a new one from Roger and replace (easy).
Old Nov 5, 2018 | 09:42 AM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Not sure about this, but the float itself might be the failure point - the float after many years sitting in hot coolant begins to decay and swell.
I pulled two last weekend and they crumbled, leaving behind the magnet ring. The sensor did still work when I moved the ring out of range.
Maybe a 3D printed replacement would save them?
Old Nov 5, 2018 | 01:12 PM
Schocki's Avatar
Schocki
Get a new sensor from Roger, done. Bridge the connector first to see if the warning disappears.
Old sensor after 20+ years in coolant. Not floating anymore.
Old Nov 5, 2018 | 02:11 PM
Kevin in Atlanta
So a float replacement would restore the sender function?
Old Nov 5, 2018 | 04:03 PM
Schocki's Avatar
Schocki
Yes, it would.
Old Nov 5, 2018 | 06:00 PM
Kevin in Atlanta
So, here's a late revision of the sender.
The magnet is inside the plastic float. Seem to be easy project for 3D printing.
Dissected coolant level sender
Old Nov 5, 2018 | 08:23 PM
awilli6's Avatar
awilli6
I cleaned the float and it began to work. Probably just temporary but there was a lot of gunk. I’ll plan to get another one and a metal expansion tank in the near future. Thanks for the help.
Old Nov 6, 2018 | 12:43 PM
Luis A.'s Avatar
Luis A.
Generally I'm not a fan of ghetto fixes but I was able to effect such a repair which, a) being invisible, b)working perfectly and c) given the cost of replacement sensor, I was perfectly satisfied with and will be 100% reliable for decades to come. I fashioned a replacement float from closed cell foam. You need to clip off the bottom "T" disc that holds the float in place and salvage the ring magnet. The resulting foam cylinder is much smaller than the original material as it has much higher buoyancy. I added a SS washer for necessary ballast but it distorts the magnetic field so play with the new magnet/foam assembly to ensure it only activates the reed switch in one (low) level position. Initially mine activated at the low point but also at its highest point, which is not correct behavior.
Old Nov 8, 2018 | 08:01 PM
dpower$'s Avatar
dpower$
All you guys know what and where everything is on these cars. For those of us not so educated...where on the car is this coolant float thing and how do you get to it? Thanks
Old Nov 8, 2018 | 08:50 PM
Wisconsin Joe's Avatar
Wisconsin Joe
It's in the coolant expansion tank.
You get to it by lifting the hood.
Somewhere on here is a pic of what's under the hood. Labelled and everything.
There's a similar pic of what's underneath the car.
If someone would post or link that, it'd be great.
The coolant tank is at the back of the engine bay, on the passenger side (right side for left hand drive cars).
It has the 'radiator cap' on top.
It was originally white plastic. By now it's usually pretty yellow.
Old Nov 8, 2018 | 09:08 PM
jschiller's Avatar
jschiller
Look here:
http://www.porsche928.be/index.php?p...ails-de-moteur
Old Nov 9, 2018 | 03:42 PM
dpower$'s Avatar
dpower$
Thank you
