Knock solution; seems too simple? Gasoline questions
#31
Didn't see where, if at all, it was stated the original fuel was E10 or not?If it was E10, there is always a small chance that there was a phase separation in the Gas Stations tank. And what you filled up with was lacking the ethanol octane addition.
if the throttle switch shows any flakiness, then replace it.
cannot figure out how and why that happened. in my mind, it suggests my car is CAPABLE of this
and that there is a solution at hand...???
The hammer only tells you that EZK is detecting knocks, but not which cylinder(s) or what RPMs. These would be useful things to know.
Fuel is a variable, but octane is not easily verifiable. In any event an S4 should have few if any knock-retards on premium gas
Have you run the WSM fuel-flow test? (Disconnect the return line at the tank and divert it to a measurement jug, jumper the fuel-pump for 30 sec and measure quantity-- should be 1.25L if I recall correctly). A weak fuel pump or a clogged filter will cause fuel pressure to drop at WOT, and a lean mixture. Knowing the L/min flow through the whole fuel system is an important data point.
Did the injectors come with a test-sheet showing flow rate per injector? Where did you install the weakest ones?
#32
Part-throttle and you are getting knocks at 4K rpm? Are these stock brains or did someone slip in a set of Autothority chips?
After you did this run what number the display show?
#34
So to answer the question- the display on the hammer showed the number 1.8 - correct?
#35
OK- so what criteria are we going to use to define that there is a problem?
from the forum posts. in my mind, I have determined that knocks retard timing, and thus performance. are you suggesting, that nothing it wrong and this is all normal?
In any event an S4 should have few if any knock-retards on premium gas,
as if the common denominator, was the Shell gas. now it seems like that is out the window...….unless, (big stretch) the next few gallons I put in the car diluted the super fuel??
that seems far fetched, but, as we all know, anything is possible????? I am more than curious.
#37
I guess for one, jim's statement from post #28, as well as others that have told me I should see zero knocks; only going by what I have been told here and what I read.
also, since I WAS able to record zero knocks, that suggests, that it is possible. what I would like to learn, is why was i able to get that result yesterday. originally, it seemed
Zero would be ideal.
But it's not entirely a realistic goal.
We have knock sensors because we have a 'more aggressive' timing map, than say a 32v 5l S3. THEY should never have knock, because they have no way to ID it and manage it.
I can induce knock, just one or two, on demand in almost any driving condition.
Some knock is natural..is just fine.
But there are a staggering amount of variables...logging knock counts only, and throwing very subjective testing at it, is...interesting. But wont lead anyone to more knowledge on how/why/what.
A sharktuner would be very nice here.
#38
with all that I have done, I don't think I am far from a solution. I am sure, with this communities help, I can get this sorted.
I will be doing fuel pressure and delivery tests later, and perhaps that will show something? although, the only possible (not likely) item is fuel filter.
Not sure if the FPR or dampers could cause a lean condition??
wish there was an ST2 nearby...….
#39
regarding fuel pressure tests, WSM says jumpered pump and car not running is 2.5 bar + or - 0.2 bar, and 2.0 bar at idle.
is there a spec for pressure under a variety of RPM's?? or are those two measurements adequate??
#40
If the system did not work then logic suggests they would not have fitted it. The stock system pulls timing by up to 9 degrees in three incremental steps of 3 degrees. In ST2 we can alter the increment size and the recovery period. When I was setting up my system I did the testing with increments of 1 degree to help me understand exactly what was going on and with patience managed to work out when knock was consistently being detected and thus pulled back as appropriate. I was running my current setup before I acquired ST2. When I lost my late S4 we opened up the motor and visually it was perfect- no signs of damage on the piston crown and very little in the way of deposition. When I first used ST2 I saw some knock events and they were invariably on either No6 or No2. Testing with a programme mod that Ken prepared for me, I was able to ascertain that at high rpms I had to pull about 2 degrees on 6 & 2 to get a more level playing field such that other cylinders started to knock in the same rev band. This then begged the question as to whether we can deliberately set more advance by say 3 degrees and then rely on the system being able to safely pull back some of that if it proves to be too much knowing that there is still 6 degrees of retard in the reserve. This I have not tried. Now I understand RON98 has just arrived in three garages - whether or not I can be bothered to go through the process again remains to be seen.
So, as I recall [but have not checked recently] the Porsche WSM criteria based on knock count is 50 knocks per 10,000 firing events is acceptable. Last time I read about this it said the display reads in numbers like 1.8 which equates to 18 events and if the display reads above 5 [i.e. 50 events] there is a problem. It also said there were two types of tester= whether they are both the same I know not.
Considering the above is your "18 knock count" relevant especially when you have seen smaller numbers and even zero?
#41
Those numbers are for the earlier 32 valve model- on your engine the same case number should read 3.8 barg if I remember correctly. That is why some earlier models have 24lb injectors
#42
The obvious question one has to ask is whether anyone has ever seen a 928 kitted out with the EZK system experience engine failure due to knock damage? I for one have never heard of such
in an effort to stop timing pull back. as WSM states, I am well within the allowable 50, but, I think I can do better and make the car better as well. I am using the KTS 300, and there are no decimals
in the display. maybe the 301 has this?? so the displayed 18, is a true 18.
fred, regarding your experience, the sharktuner would surely help take the guess work out of my situation.
Do you have a stock exhaust?
are you saying, an X pipe would help here? (might be a good excuse to move that up the priorities list...lol)
#43
I would be an idiot to not be concerned about potential damage due to knocks, but in this instance, I am attempting to get the most power out of this car by finding the source of these knocks,
You would only be an idiot if you knew your car was experiencing a potentially destructive mode of operation and ignored it but that is just not the case here. In reality you are probably more concerned about what you have picked up on the subject matter and the real question is whether it is a problem or not . It is a bit like modern medicine- nowadays doctors can see much deeper into our bodies than they could just a few short years ago- trouble is they find things that were simply never found previously- but somehow people survived and life expectancy increased. Trouble is when we know something is not how it should be we tend to worry more about it - a double edged sword as it were.
One thing you should consider is that not all engines are equal- some perform significantly better than others and Porsche knows this but when they tell you your engine develops 330 bhp what they mean is they all develop that and by extension, some develop even more. Now, if a given motor has a tendency to knock is it because it is burning too much oil that causes a reduction in knock resistance or could it be because it is swallowing more air/fuel and thus more prone to knock events happening at a given operating point?
Regarding the X pipe on its own it gives some performance improvement- if it is breathing better at a given operating point, is it going to be more prone to knocking or less prone?
#44
Originally Posted by left
[color=left=#222222
[color=left=#222222
You would only be an idiot if you knew your car was experiencing a potentially destructive mode of operation and ignored it but that is just not the case here. In reality you are probably more concerned about what you have picked up on the subject matter and the real question is whether it is a problem or not . It is a bit like modern medicine- nowadays doctors can see much deeper into our bodies than they could just a few short years ago- trouble is they find things that were simply never found previously- but somehow people survived and life expectancy increased. Trouble is when we know something is not how it should be we tend to worry more about it - a double edged sword as it were.[/color]]
all I want to do is put this car in best shape that I possibly can!
just did the fuel volume test and it is near spot on the 1.25L. not sure if that's a good thing? WSM says that is the minimum, so with new bump I was thinking (hoping) it would pump more. did this 3 times and each time was nearly the same
now for the pressure testing. the loaner tester I got does not have the correct fitting for the fuel rail. does anyone have the size thread??
#45
Paul, in post# 28 I said "few if any", not zero. I think Dave (in a previous thread) and others have posted that S4/GTs generally show zero knock-retards, but it is highly variable.
There is one part of your test that I think is significant: You reported some detected knocks in the 3000-4000 RPM range NOT at wide-open throttle. The S4 and GT advance maps have a lot of headroom in the partial-load area, so knocking there is unexpected. Which is why I asked about Autothority chips-- those add a lot of advance in the middle of the map and will certainly make it prone to knocking.
Are you sure that you have stock chips? The only way to know for sure would be if (a) you are the original owner, or (b) you looked inside the EZK. Assuming the first is not the case, you should do the second. Because what you describe would fit those chips. Stock chips will have a paper label with a Bosch part#, post a pic if not sure.
