Exhaust Tip
Inventor
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Well, my new auto-darkening welding helmet from Harbor Freight (on sale for $50!), works great! Maybe a little too well...
![](https://members.rennlist.com/porken/Trident1.jpg)
![](https://members.rennlist.com/porken/Trident3.jpg)
![](https://members.rennlist.com/porken/Trident2.jpg)
![](https://members.rennlist.com/porken/Trident2Edit.jpg)
I'm torn between gagging, and actually liking it. It's kinda of got that anime' Sci-Fi look.
I couldn't find the dual tip I wanted, on a Saturday, so I took three single resonators and got over-creative.
The lower right pic shows what my original plan was. Tips pointing up to aid aerodynamics (hot air jet into the turbulence zone).
Side note: you can see the extra wide stance with my (new to me) S4 wheels and 25MM spacers.
~thread~start~
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
~thread~start~
" Tips pointing up to aid aerodynamics (hot air jet into the turbulence zone)"
--Now if you added F-18 thrust reversing deflectors, the big GTS brakes wouldn't be necessary!
I'm envious - don't know how to weld! But, as you do weld, consider adding a fourth tip to give a 'quad' with two per side (like the after market 993/996 units). It might look OK as you've already switched the first pair to a straight back location (from stock)???
PorKen,
You never cease to amaze me. I think the dual tip is cool, but the triple tip looks like a Gembella space machine. Power to ya all the way.
You have quite the ability to weld. How difficult would it be to turn a 3" inlet monza tip into a 3 1/2". The trick would be in welding it so that the 3 1/2" cross-sectional surface area remains no less than 3 1/2" (9.6 sq in, oval-like), as it transitions into the dual tip.
Inventor
Quad tips would look cool, and not too difficult:
![](https://members.rennlist.com/porken/QuadTip.jpg)
I'll have to make a heat-shield where it passes under the gas tank.
On welding: I have a Lincoln 110V Mig welder, with flux core wire, combined with the auto-darkening helmet, it is really easy to weld (non-structural items). Pretty much like a hot-glue gun.
I think I'll put the Fifth Element tip on my truck, instead...
Inventor
Jadz928,
When I redid my 3" system, I chopped my Monza inlet off, and welded on a larger and angled inlet made from a piece of 3" pipe, cut with two ~15 degree angles to make a point. Then I pounded the points around the intersection of the resonators and welded it back together:
3" DIY Exhaust
3" DIY Exhaust
![](https://members.rennlist.com/porken/HammerDetails.jpg)
Man, once you sell that car some poor mechanic is going to course for a month about you as the most stupid PO of the world.. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
(because he don't understand the ingenuity of course..)
Inventor
Jag är inte så smart, snarare ointelligent eller dum, men minst är jag inte Skånske! ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Here's a detail shot:
![](https://members.rennlist.com/porken/TridentDetail.jpg)
I'm starting to like the 'Trident', more and more...![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
The quad tip is actually a little more of a challenge than I thought. The gas tank hangs down lower than the battery box so I can't go directly under it. If I go along under the bumper then the slush-box radiator won't get any cool air. Maybe, if I move the radiator over where the cutout for the stock tips is...
All the smart people in Sweden come from Skåne, but our dialect is a bit different compared to the puffs in Stockholm area..
That exhaust tip looks wild, I've never seen anything like it.
