928 Forum 1978-1995
Sponsored by: 928 Specialists
Replacement Keys Using a Photo?
Old 10-06-2018, 07:43 PM
Randy V
Randy V's Avatar
Default Replacement Keys Using a Photo?
I can't seem to find the info on the company that does this?
I should really add that to the FAQ sticky - thought it was already there.
Thanks for the assist!
Old 10-06-2018, 07:46 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,577 Likes on 1,244 Posts
http://www.keys4classics.com/html/Por928.html
Old 10-06-2018, 08:27 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,283 Likes on 1,265 Posts
I had a set of two of the same keys made for my 79 it cost 164.00 US dollars ,
made from a picture,
the keys worked perfectly.
Keys for classics expensive but worth it.
NOTE dont post pictures of the keys for your car,
someone else might like the key as much as you do.
Old 10-07-2018, 11:22 AM
ROG100
Basic Sponsor
ROG100's Avatar
Over $200 from the dealer when cut to VIN and there is a large possibility they will not fit.
The fact that they are cut to match the exact key you are using as opposed to the key that matches the VIN is a big plus.
I have been using keys4classics for about 12 years with zero issues. Every key made fitted and worked.
Old 10-07-2018, 12:23 PM
XS29L9B
XS29L9B's Avatar
I am thinking of doing this. Can they do all Porsche Keys, or just some? Wondering on limitations.
There was a flyer being passed around at Frenzy. Where did I leave it?
Old 10-07-2018, 01:17 PM
Ducman82
Ducman82's Avatar
I had the dealer cut me a key, then re did all the worn pins in my locks to the new fresh key. then had Keys4classics make me a spare.
Old 10-07-2018, 01:37 PM
jetson8859
jetson8859's Avatar
He cuts keys for many different cars, I would expect other Porsches from same time frame no issue. You can check his website for more info.
I have had Stewart cut keys for all 4 of my 928s. I ordered just the blades then key heads from Sonnen so I have 2 "original" keys for each car. Also ordered the black spare, which looks like red key. No issues with any and the 87 key was really worn down.
Old 10-07-2018, 01:40 PM
Jerry Feather
Jerry Feather's Avatar
I remember seeing Mark A.'s son cutting new 928 keys at Sharktoberfest a few years ago, there. I am not sure what the extent might be of their service, but could be worth learning.
Old 10-07-2018, 01:52 PM
Fracture
Fracture's Avatar
I used Keys in the Post on advice of a mention here
https://keysinthepost.com
2 keys, around $65 US, both start and unlock the hatch
but door locks, no joy yet
Old 10-07-2018, 06:11 PM
GerritD
GerritD's Avatar
Default 928S euro spare key by keys4classics
I also sent a photo of my key ( since I changed my ignition keylock by one of a S4 and I only had 1 key)
to keys4classics.
I paid about $100 for the hardened key material (As original Porsche key)
It worked like a charm !
I also re-keyed the barrels of all my locks , so door-, ignition-, trunk- and fuelcaplock can be used by 1 key.
At the same time I also installed an aftermarket remote central locking system ($50) which is really practical and also
safe since code is rendered every second.
kr
Gerrit
Old 10-07-2018, 07:14 PM
Randy V
Randy V's Avatar
Thanks to Rob and Fracture!
Old 10-07-2018, 09:54 PM
buccicone
buccicone's Avatar
Used keys4classics several times. Best keys bar none.
Old 10-08-2018, 05:36 PM
dr bob
Chronic Tool Dropper
dr bob's Avatar
Hey Randy, If you are headed north to Sharktoberfest and have a working key, they can cut a duplicate for you at 928 International while you are there.
Old 10-09-2018, 12:19 PM
Randy V
Randy V's Avatar
Now that's a great idea.
One more reason to go this year.
Hey .Mark A - will you be cutting keys this year?
Old 10-09-2018, 12:38 PM
997TTEQNY
997TTEQNY's Avatar
My car only came with one master key. Per the manual Its the only one which will deactivate the annoying alarm. Will they keys for classics version also deactivate the alarm as well?
tx
Kurt
Quick Reply: Replacement Keys Using a Photo?
