928 Forum 1978-1995
Sponsored by: 928 Specialists
flat plane crank conversion
Old 09-28-2018, 03:07 PM
uraniummetallurgist
uraniummetallurgist's Avatar
Default flat plane crank conversion
I've read the advantages of flat plane cranks versus conventional cross plane cranks- better scavenging, lighter mass, etc albeit at the expense of increased vibration. That said, I wonder if there would be any improvement/reduction in the oil consumption in my GTS motor due to the splashing and misting caused by the cross plane crank. It looks like the splashes per rpm would be half those of a cross plane but not sure if it really matter in mist formation due to the GTS' longer stroke.
I've had good success with a vacuum system but wanted to get advice on the use of a flat plane as I may some day want to open the motor up to drill oil drain holes for the pistons.
Thanks,
Joe
Old 09-28-2018, 03:12 PM
drnick
drnick's Avatar
Joe, what kind of vacuum system are you running?
Old 09-28-2018, 03:52 PM
uraniummetallurgist
Hi drnick:
I have one of Colin's early vacuum systems and am quite pleased wit it.
All the best,
Joe
Old 09-28-2018, 04:02 PM
Ducman82
Ducman82's Avatar
i had that system as well. made my own AOS (air oil separator) as well. good breather baffling and that should be all you need. i never burned/sucked in any oil. flat plane would sound nice, but you are looking at re doing the ignition firing order as well. maybe even differently clocked cams due to the pistons orientation being changed? not sure, but i just read where a guy put a flat plane in a Z06... stupid expensive custom stuff. but it does sound nice.
Old 09-28-2018, 04:29 PM
uraniummetallurgist
I must admit that I saw the same article this am and that's the motivation.............https://jalopnik.com/some-mad-genius...ank-1829362964
Happy 9/28 day!
Old 09-28-2018, 04:39 PM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
Camshafts need to match the firing order.
So at bare minimum this would mean:
1. One off crank
2. One off set of cams - unless the blanks Colin had made could be made to work.
3. Standalone ECU
One thing to ponder, will this crank be designed around stock 928 rod bearings? If not, new rods are needed.
The 8 different length intake runners of the stock intake are bad enough with a stock engine and batch fire ignition / fuel. Going through all this work and keeping that would seem silly.
I love the idea just for the crazy sake of doing it.
Old 09-28-2018, 06:05 PM
76FJ55
76FJ55's Avatar
What about using 944 cams? As an inline 4 they are running a flat plane crank, so would have the correct lobe clocking for a flat plane 928 motor.
Old 09-29-2018, 10:37 AM
V2Rocket
Rainman
V2Rocket's Avatar
the firing order is still wrong as that cam is made for 4 firing events per cycle...you'd be firing 2 at TDC simultaneously
though i have wondered if a 944 crank could work for this in a 928 block since the bore pitch is the same. would need a lot of work to fit a 2nd rod on each journal though (or get skinny rods)
though really, if you could jam a set of "180-degree" headers under a 928 body it would give you all of the sound and power benefits without having to change crank/cams/etc.
Old 09-29-2018, 11:18 AM
SwayBar
SwayBar's Avatar
If you were serious about this, you'd be much better off buying a fully-sorted factory flat-plane crank engine such as the Ford Voodoo used in the GT350/GT350R from eBay along with its ECU.
Old 09-29-2018, 11:34 AM
uraniummetallurgist
That is certainly a consideration. I could do the swap and have my GTS motor to boot.
Old 09-29-2018, 12:10 PM
SwayBar
SwayBar's Avatar
Here's an excellent article showing the many things the Ford engineering team did building the engine.
Ford Voodoo Development...
Like Erik stated, there's a lot more to it than 'simply' changing the crank.
Old 09-29-2018, 12:22 PM
Bigfoot928
Bigfoot928's Avatar
you would be better off making headers to make it scavenge like a flat plane motor. It's been done before. The best person to pose this question to would be Bob Norwood. I can ask him next week about the gains from converting the 928 V8 to a flat plane..
Old 09-29-2018, 03:30 PM
slate blue
slate blue's Avatar
As a person who does crazy projects, you'd be out of your mind to do this. �� The power gain if any is very very minimal. It's been tried in Nascar and it wasn't worth the effort. What you want is lighter parts and more revs with better breathing. The 928 engine is built like a truck motor, everything is heavy, do what Sterling says or what I'm doing is similar, which is a tri-y setup.
Old 09-29-2018, 03:47 PM
ptuomov
ptuomov's Avatar
What's the theory that crankcase gas flows would improve with the flat plane crank compared to a cross-plane crank?
Old 09-29-2018, 03:59 PM
icsamerica
icsamerica's Avatar
Its a novelty. Nothing more. The 2 valve SS camaro with a cross plane still bests the 4 valve flat plane Mustang is almost every performance metric.
No doubt a flat plane is cool but for all practical purposes it justs a novelty.
Cant we just leave well enough alone....928s are fine and quite enjoyable as built...upgraded parts from later model are cool but when you start with sillynesss like custom cranks and cams you run the risk of ruining the car and making a 1 off noone else cares about and in the process spending more money for a lesser result.
In short...if you want a flat plane buy a mustang...it will be cheaper, perform better than a homebrew and actually worth something when you are done playing with it.
Quick Reply: flat plane crank conversion
