928S4 getting work done!!!
I finally got Sean's 87 5 speed into the shop at work to get a bunch of issues addressed! First was the AC, luckily it already had been converted to R134 so its super easy to work on and the brand new Snap On tools are amazing! Coolant was incredibly low, only had a bit over .25lbs when I stopped by, so clearly that is an issue. They managed to get the stuck trunk open, said it was just old grease-dirt that caused it. So far the list is:
AC
heater valve (probably coolant flush too)
AC control head is making odd noises, maybe flap motor behind of vac leaks?
brake inspection and flush
oil change and new pressure sender (stuck on 5+bar)
driver seat switch replacement
both window switch replacement
repair drivers side power mirror, glass is loose
determine source of parasitic loss on battery
inspect power steering (seems heavy to me, but could be fine)
install new front coil overs (way too low) + alignment
new transmission oil
Then after all that is done.....time to wait for the body shop for a full repaint and a new windshield....
AC
